So my kit from HK arrived yesterday and I should note that this is my first build ( If you see terrible mistakes don't hesitate to shout;))
Soldered the carbon rod using some super glue. I installed those holders just in case even though most probably am gonna put the elevator end radder servos on the wing itself
Glued the 2 wooden parts with white glue , then using superglue to the foam and around it some epoxy just to make sure ( Did I used too much glue ?:P)
Here is a close up
Thats all for today, also some question :) :
1) is there an easy way to aline the back wing (elevator) with the hole stracture in order to be 90 degrees with the fuselage?
2) shall i use superglue for epp to epp or buy some CA?
Comment by Yiangos Yiangou on April 29, 2011 at 11:23pm
Comment by Jimmy P. on May 6, 2011 at 11:29pm Jimmy P.
What motor/prop/battery combination are you using. Are those batteries in series? Nice pics by the way.
Jason
Comment by Jimmy P. on June 1, 2011 at 11:45pm
Comment by espenthrondsen on June 15, 2012 at 10:32am Did you fly this plane ? Do you have a parameter file to share ?
Guys, what is the best prop for this plane? I'm using NTM35-36a-1400Kv motor and 60A ESC. Thanx!
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1356 members
54 members
203 members
88 members
24 members
Powered by
