Over the past couple of weeks I have been busy reworking my original APM Mission Planner. Together with my partner/designer Samantha Nelson we have focused on improving the APM Planner’s interface, ideally resulting in a more intuitive user experience.
Below are a couple screenshots of the new APM Planner!
APM Planner Version 1.0.0 can be downloaded here -
https://code.google.com/p/ardupilot-mega/downloads/list
Comment by Sonia Kouassi Eba Kaudjhis on October 24, 2011 at 11:08am
I dowload google earth plugin on my computer for my google browser
I would like how link Google earth plugin beetween APM planner 1.0.84
I am so confused
Comment by jim C. on October 24, 2011 at 11:18am
I would like to know what is the command to shoot a camera on a waypoint?
Comment by Martin Bellomo on October 24, 2011 at 11:23am
I think it depends on what type of shooter you use.
I have two different cameras and I use DO SET SERVO with one and DO SET RELAY with the other
Comment by Amilcar Lucas on October 24, 2011 at 12:51pm
Martin, Jim
We have some experimental code where you trigger the camera via a mavlink message from the GCS mission planner, or via a mission command.
It supports both servo, relay, or a camera electronic trigger signal.
But the code is still experimental, but stay tunned, it will come.
Comment by Adi Membala on November 9, 2011 at 10:28am
hy..
can i convert the tunning data into notepad??.
thanks
regard
Comment by Aaron Curtis on April 7, 2012 at 10:35am
Just wanted to say thanks, Michael, for fixing APM planner so that it works under Mono! I'm using it in Ubuntu without a hitch! Amazing!!
Comment by Wong on July 10, 2012 at 9:13pm
Hello! Michael:
I used MAVLINK for my fix-wing FPV OSD, can I use Mission Planner even if my OSD isn't the FREE or GNU software? It use the Flight Data&Planner.
Comment by Michael Oborne on July 11, 2012 at 3:22am
so long as it talks valid mavlink, and can process paramater requests it should work fine.
Comment by Wong on July 11, 2012 at 7:47am
Yes,it work fine now. I mean that if I can use it freely?
Comment
