I bought a cheap RC Futaba T7CP on ebay, but I spent 3 days in order to understand the right configurations of switches to enable 6 flight modes.
Here, my solution. Hope useful for the community.
(I used some hints from other blogs)
1. I used SWE and SWA. SWE is a 3-position switch. while SWA is on the left and it is a 2-position switch
2. You have to set End Point, SubTrim and RT in MIX. First, set the ENDPOINT for CH5 to be 50%(UP) and 52%(DOWN). You can tune the values until the pwm value(see point 5.) are right.
3. Then, set the SUBTRIM for the GEAR (CH5) to be 100%
4. Configure a P-MIX ( I used P-MIX1) to be without offset, and with the following rates: 24% and 60% (You can switch between the rates by using the 2-position switch)
5. Exit (END button) and check the pwm values in CLI->test->pwm.
6. Configure you radio in CLI->setup->modes
NOTE: Maybe, in order to not mess the radio setup, you have first to setup radio channel: CLI->setup->radio
I attach some pictures for sake of clarity.
Regards to everyone
1. First set the endpoint for Rudder (CH5)
2.Then adjust the GEAR of CH5
4.Finally, set the mixing program. I choose P-MIX1
5.Set the Master and Salve Channels (I used for Master CH7 and for slave CH5). Set the 2 rates : you can switch between one and the other by toggle the A switch
Comment by Brett Horton on June 13, 2011 at 7:44am Need to clarify the P-Mix settings
Comment by giu on June 13, 2011 at 8:11am
Comment by Brett Horton on June 13, 2011 at 8:20am
Comment by Ferran on June 14, 2011 at 4:56am Hello, for the switch assignements, did you use the default settings? Switch E controls CH5 and switch A activates or deactivates P-MIX 1. Am I right?
Can you put some more screen to see the values you set up for the P-Mix?
Thank you for your work.
Comment by Assaf Weiss on June 19, 2011 at 12:36pm How do I configure the P-mix to be without offset??
Thanks.
Comment by Assaf Weiss on June 19, 2011 at 1:06pm Hi, found out regarding the offset.
But I have another problem.
I configured 6 modes in the CLI.
But when I get back to the flight data, under status, the "mode" field doesnt correspond to the modes I configured in the CLI (I am connected via USB) which one of them is the correct indication of the mode?
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
11 members
182 members
1290 members
684 members
Powered by
