The T6EX doesn't have a 3 position switch channel, so I had to combine channel 5 and 6 to get four modes. I made it work with a pot that has double terminals for each knob position, so that way there is always 2 pins to connect cables to for a single position.
Think of this knob as a bridge between same terminals: A to A, B to B, etc, closing the circuit to ground.
Channel 6 is connected to a terminal A and a terminal B from the opposite side.
Channel 5 is connected to a terminal B and C.
This is how the pot look like:
I got this switch at the Home Hardware in College st and and Spadina Av, Toronto, Canada. Sorry I don't have to much information about it. It's just a position knob.
Later, in the radio, I set up 2 PMIX mixes. they appear as PMX 1 and 2. PMX 1 it's at +70%, MAS (for master) is channel 6, SLV is channel 5, SW is channel 5.
PMX 2 is set to -60%, MAS ch6, SLV ch5, SW to ch5.
The final look:
Let me know what is not clear and I will edit this blog!
Enjoy-
Comment by Scott Palmer on November 5, 2011 at 9:18am
Could you do 3 fight modes with the T6EX with out having to add a pot? and just mix 2-Two postion switches?
Comment by estebanflyer on November 5, 2011 at 5:45pm
I'm not sure, try with programming the radio the way I did and without mounting the pot. I have a feeling it could work. Make sure to read the radio values on Mission Planner (radio tab) as you toggle the switches to be sure everything is fine.
Comment by Scott Palmer on November 6, 2011 at 6:20am
Thanks.
Comment by Cliff Grey on August 22, 2013 at 5:04am
Could you attach a drawing like a schematic.  It doesn't have to be fancy, I'm having a hard time following along. Thanks
Comment by Tedd Jensen on January 25, 2014 at 9:39am
Yes a Schematic would have been great :)
Comment by Alex on January 23, 2016 at 11:15pm
You can definitely use the menus in the radio to mix 2 position switch channel 6 into 2 position switch channel 5 to be able to select 4 different flight modes using the two switches. No hardware changes at all. I just did it and it works great. To do it make the Mix Master ch 6 and the Mix Slave ch5. I did 70% mix and it worked well and puts the PPM signals well within the brackets for four different flight modes.
FYI Doing it this way means you can't use ch6 for anything else (bomb drop, camera shutter, etc).
Comment by estebanflyer on January 24, 2016 at 7:26am
Huh! great! tell the admins so they replace my intructions with yours! at the time i had tried everything with no success
Comment
