Check out our unique in-flight starter motor for the MVVS 26cc on a custom built Senior Telemaster.
The system is lightweight and robust. Works from a cold start. Works again and again... it is great for extreme long duration flights and vibration free (i.e., no image blur) video or stills while the engine is off. Also, for all those people struggling with gyro drift, you can get a good gyro fix when the engine is off as well.
Cheers from the MotMen UAV team, Newcastle, Australia.
Comment by Robert Dielenberg on July 11, 2011 at 4:42am
Comment by MarcS on July 11, 2011 at 5:18am OK, the Aerosonde motor is definetely too much... Scaneagle on the oher hand uses a quite similar motor like you do (3W 26cc I think) just outfitted with a smaller carburetor...
I´m just sceptical if you really win efficiency (fuel consumption per flight hour in the end...) in going up fast and gliding down. Your engine system is definetely heavier (starter + more powerful for climbing).
Comment by Alexey Burlakov on July 11, 2011 at 5:55am I tend to agree with MarcS. While ability to take vibration-free photos is good, stopping-and-starting engine doesn't seem to me the optimal power-consumption scheme.
Unless you intend to use termals as source of power, constant-running engine on it's best-efficiency rpm and carefully chosen prop will allow you to fly longer on cruising speed than iterative start-stop climb-glide pattern.
Prop optimized for high-speed cruise will probably cause problems on take-off but this can be solved in several ways.
I think their remote start system is really slick. There's clearly a market for that in the R/C world...AP R/C doesn't seem like the right place for it but what do I know?
Still a very cool system.
Comment by Robert Dielenberg on July 11, 2011 at 7:39am
Comment by Robert Dielenberg on July 11, 2011 at 7:51am Cool, what about telemetry data? :)
I'd be happy to add support to my GCS: http://code.google.com/p/happykillmore-gcs/
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
