From Hack-a-day. This ducted-fan beast uses the Sparkfun 6DoF IMU that Jordi wrote the software for. No, it hasn't flown yet.
Behold the Land-Bear-Shark, a quadcopter on a rather grand scale. At a full eight kilograms it’s an easy target to compare the [Howard Hughes] behemoth, but in addition to the weight, this still has yet to make its first flight.
To give you some scale to the image above, the board at the center is an Arduino. It controls the beast, along with the help of a SparkFun IMU board which rides atop. Really, if any quadcopter of this size has a chance of working, this should be the one. The construction is beautiful, making use of carbon fiber rod along with 3D-printed connectors to assemble the frame. A lot of thought has gone into small things like conserving weight used on the landing gear, which are incorporated into the bottom corner brackets. The batteries are connected in a manner that makes them easy to adjust, acting as ballast for balancing the craft.
Comment by fibrewire on July 20, 2011 at 12:25am When I say large blades, I mean blades that serve the same purpose as an airship. So these blimp-blades would be covered with photovoltaic film, would make the variable-pitch quad rotor extremely light, and make it possible to cruise high altitudes practically and indefinitely. The blades could charge the vehicle's electronics and power the onboard electronics. A quad-rotor airship...
Comment by Coptaire on July 20, 2011 at 3:02am If the control surface impacts the airflow in this T (supposing top is closed and bottom open), this is how it impact a sort of turbulence, where the airflow can fill the T, more or less.
As the open T side is rigidly oriented downward, the influence of the control surface could be limited, except if proper dimensioning of the whole system is adequate.
There is a lot of MAV example where a ducted fan/shroud propeller features vectoring vanes, on 2 axis, and this is a proven design.
As far the Huge Quadrotor is concerned, I understand that the servo at each fan is to counter the rotation generated by 4 CW fans.
After this "neutralization", I understand the attitude stabilization and governing is the same as used in our quad kopter.
A last remark is to notice the huge powerplant needed (LiPo characteristics) to get enough thrust from these ducted fan, based on high speed airflow, where tubing the airflow is just a first step to take advantage of aerodynamics. This is high voltage, high amps project not guaranteeing a manageable and satisfactory thrust to weight ratio.
My ongoing Propeller Shrouded Project (already 2 shrouds builds for test bench experiment is aimed at maximizing the propeller/multiblade custom rotor thrust by aerodynamics to get more thrust, or to reduce the needed power.
I have no particular belief, I just build custom shroud, stator, rotor based on different studies, and I just measure the outcome by experiment, to conclude if it is worthing shrouding, or not, applied to RC scale dimensions (Reynolds number impact).
My upcoming tri-shrouded, and quad-shrouded is perhaps at the opposite of this huge thing, consideirng the aim of reducing the powerplant.
Comment by Chris on July 20, 2011 at 5:55am old shit with bad efficencty and much noise, bad control stability.
impellers are not a good choice for a hover platform
the Levitake.de Copter is more then 3years old
here has some one tried to make some tests with the chassis from levitake, but its not good
Comment by Coptaire on July 20, 2011 at 9:47am @Chris
the Levitake.de Copter ???
But, but, it is not my impeller based UFO !
Please visit my Propeller Shroud Project, you will see my homemade shroud, not exactly the same thing!
Soon, you will be able to criticize my tri-shroud/quad-shroud.
Comment by bGatti on July 20, 2011 at 9:54am
An other solution is to use 1 motor and variable pitch propeller
http://www.virtualrobotix.com/video/hg3-willy
... we yet fly last year in that configuration .... this year instead i develop a lot of heavy lift as
VR Dragon
http://www.virtualrobotix.com/profiles/blogs/foxteam-support-and-im...
best
Roberto
Another Example of Heavy lift developed using mp32 :
http://www.youtube.com/rnavoni#p/u/27/cXRwh7zsD8s
I CW for stbilize that kind of Quad you need to put flap above the ducted fans so you can govern the yaw. I doing a lot of test on a special huge quad and that is better solution
Since the topic is big, here is a full size octo.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.8 members
184 members
24 members
1283 members
180 members
Powered by
