Multiwii Copter Scarab 12 Build with APM
Another LOS video, recently done, love this one
http://youtu.be/FM3s2emlQuc
Just a short Blog on this build, it's been a pleasure to build the kit, and i think i might just get another, maybe even the new Trikopta.
Specs so far
1 x Multiwiicopter Scarab 12
4 x Carbon Bird 750kv motors
4 x Rc Timer 30amp ESC
1 x Arducopter Power Distribution Board
1 x Castle Creations 10amp External BEC
4 x MPI 10 x 4.5 SF Props
1 x Spektrum AR7000 Rx-er
1 x Ardupilot Mega Board with barometer and gps
1 x Thunderpower 45c 3s 2250 Lipo
A quick word on prop balancing, i never used the normal method of removing material from the heavier blade or hub to balance, i chose to add weight to the lighter blade to equal the heavy one, as well as adding weight to the lighter side of the hub to equal the heavy one. A principal that i use on RC Helis, as you never remove material from any of the blades.
I used clear nail varnish for this, as it has proved to be very durable and weather resistant over the years of using nail varnish.
Video of the maiden flight above, lots of PID tuning left to do.
Pics of build in my Album under
http://www.diydrones.com/photo/albums/multiwii-copter-scarab-12-build
Just uploaded another video with the most stable PID's i can get at the moment.
This is the link
http://youtu.be/JsD8HzphJFs
This is a pic of the latest PID's
http://diydrones.com/photo/fairly-stable-pid-s?context=album&al...
My biggest problem is trying to weed out the slight oscillations and keep the quad stable without it being sluggish. The rate roll and pitch are down as far as i can seem to get it without losing stability, as well as the stabilize roll and pitch. However it seems very twitchy to control, and i have about -50 exponential to try and smooth it out on both aileron and elevator.
It's tricky this PID tuning.
Any pointers from anyone out there in multicopter land.
Danny
September 9th 2011 Update
A Short LOS AV clip
http://www.youtube.com/watch?v=l7xceHKebjA&feature=player_embedded
Comment by Deemees on August 17, 2011 at 6:57pm
One other thing i am still trying to work out, is my trim issue.
I have excessive right aileron trim and back elevator, which i've had to try and cancel out using subtrim! Seems to be working without a problem as i was not sure you could use subtrim on a quad, but i can't work out why i need so much trim!
The quad is balanced out correctly, nothing is bent, motors have the 5 degrees of pitch as per the build instructions, and i even when put them back to being straight just to see if it would change anything i still have this excessive trim.
Used to traditional rc heli's and i know if your c of g is off it causes trim issues, but like i say c of g is spot on.
Driving me a little crazy
Comment by Deemees on August 31, 2011 at 8:21pm
Ok i finally figured out the excessive trim issue, it seems one of the ESC's had a different firmware loaded on it from the other three identical ESC's. So a change of all 4 ESC's was done and the excessive trim issue has gone away, along with the slight oscillations i was getting during flights.  Apparently it can be an issue were manufactures of ESC's can change their firmwares without notification or marking the fact.
Comment by Kevin LeRoy on May 11, 2012 at 8:58pm
hi guys ,
 I am very new , trying to figure out what to spend my money on ... my end goal would be to take my drone with me skiing and have it "follow me"  I have seen the very expensive Mikro copters do this , but I like the scarab frame and I am on a budget so not able to drop 20k into this :) .. Would I be able to have the following features by using a scab octo kit and using Ardupilot Mega Board in stead of the PARIS board ...
Gps Hover( keep itself steady even in the wind)
GPS return to base ( in case one engine fails , battery low  or Signal is lost it should go up to a good alt , then head to start point , and slowly land by itself )
POV camera in addition to a GoPro V2 ,
goggles to see POV .. Ground station
And final feature I would like is "follow me "  I have a gps on my helmet , then camera follows me while I ski .
So are these things possible ?  I would love for it to be .. I already fly the Scarab stealth Armour with a paris board and no longer crash , so now I want to go a bit more advanced , but have no idea where to drop my $$ lol
Comment by Chris Anderson on May 11, 2012 at 9:25pm
Kevin: ArduCopter already has follow-me mode and the rest. $860 RTF.
Comment by Kevin LeRoy on May 11, 2012 at 10:36pm
wow , i did not know this ! .. Thank you so much :) so , do you think i can drop a gopro onto that baby and be all ready to have it film me ski? you may have just spent my next paycheck for me :) lol
Comment
