Heino, Jeff E and myself have been working on updating Ardustation code to support Arductoper 2.
I think our code is ready for general use.
- Automatic antenna tracking, tested with ReadyMadeRC Antenna pan/tilt unit (even had my ContourHD cam attached to the directional antenna!)
- Manual antenna tracking (aka Antenna Test)
- Edit/View AC2 Params included PIDs
- Flight data display
Credits to Phillip Anthony Smith for updating Ardustation to support Mavlink (ArdustationPS).
Source code is available here
Comment by Whooper on November 11, 2011 at 11:47pm I have the same error message and can't find a solution. I am using "Duemilanove or Nano mega328" and correct USB port and Xbee is removed as mentioned in the manual.
Messages in the above posts suggest using a baud rate of 57600 however I don't see an option in arduino how to check this. I thought baud rate is fixed by the board selection?
Only the PWR LED lights up with LCD connected and Xbee disconnected. With Xbee connected the ASC LED also turns on (does not flash). Is this correct?
Comment by Whooper on November 12, 2011 at 5:22pm Confirmed the problem was in the 328 chip. Swapped it out for another and seems to work fine now.
Comment by Whooper on November 15, 2011 at 4:00am Some of the chips need "Arduino Uno" selected as the board instead of "Arduino Duemilanove or Nano w/ AT mega 328"
Comment by Boris Matuschka on April 29, 2012 at 5:55am Can I use the antenna tracker feature with arduplane, too?
Comment by Heino R. Pull on April 29, 2012 at 8:49am Yes you can - here is a more updated post.
http://diydrones.com/profiles/blogs/unified-ardustation-2-with-para...
Comment by Boris Matuschka on May 1, 2012 at 11:46am Thank you very much Heino! For you reply to my mail, also :-) very appreciated!
Comment
1298 members
47 members
87 members
183 members
Powered by
