Hi all friends .
This new Open Source case for Ardupilot Mega & GPS module & Receiver module & Telemetry module & Airspeed module .
Telemetry module = Xbee Pro 900MHz
GPS module = GS407 U-Blox5 GPS 4Hz
Receiver module = Hitec Optima 9
Airspeed Sensor = MPXV7002DP
Assembly Animation :
Download Clip 1 (1.59 MB)
Download Clip 2 (1.67 MB)
Mass properties :
Mass = 61.75 grams
Volume = 382.15 cubic centimeters
Surface area = 1940.78 centimeters^2
Center of mass: ( centimeters )
X = -1.69
Y = -1.59
Z = -7.44
Principal axes of inertia and principal moments of inertia: ( grams * square centimeters ) Taken at the center of mass.
Ix = (1.00, 0.02, 0.01) Px = 891.24
Iy = (0.01, 0.00, -1.00) Py = 2488.92
Iz = (-0.02, 1.00, 0.00) Pz = 2930.28
Moments of inertia: ( grams * square centimeters ) Taken at the center of mass and aligned with the output coordinate system.
Lxx = 891.98 Lxy = 32.27 Lxz = 19.30
Lyx = 32.27 Lyy = 2929.77 Lyz = -1.27
Lzx = 19.30 Lzy = -1.27 Lzz = 2488.69
oments of inertia: ( grams * square centimeters )Taken at the output coordinate system.
Ixx = 4469.32 Ixy = 198.80 Ixz = 796.73
Iyx = 198.80 Iyy = 6526.87 Iyz = 731.40
Izx = 796.73 Izy = 731.40 Izz = 2822.34
Created by ZXO003 & SolidWork 2010
Comment by george on August 16, 2011 at 12:40pm Does it not matter if the Ublox gps is positioned vertically or horizontally? I thought the vertical position was ideal but in your picture it is placed horizontally. My flying wing doesn't have the height to place the ublox vertically so it would be great if I could still get great performance placing it horizontally. Nice box btw!
the ublox has a spherical antenna, so it has good reception in almost every position
Comment by Avalerion on August 16, 2011 at 1:12pm Any ideas as to where one could get this built…?
Comment by george on August 16, 2011 at 1:36pm @Sebastian
Thankyou kind sir for the info!
@Avalerion
Maybe try ponoko? It's a bit large for my makerbot.
Comment by Dr Mike Black on August 16, 2011 at 2:33pm I can laser cut it for you, if you wish.
Its one of the things we do eveyday.
If you wish to see what sort of quality of work we do, please have a quick look at the lasing cutting on my prototype Hawker Tempest Mk5
Be good to do something different.
Hope this helps.
regards,
Mike.
P.S, not wishing to step on anyones toes here.
Comment by Sean Skirvin on August 16, 2011 at 3:54pm Dr. Mike Black, how much would you want to cut the design by Pieter van Woerkom out of the same 1.5mm multiplex? Shipping would be to Ohio, USA.
Sean Skirvin
paradigmpower_05 at yahoo dot com
Comment by Kirby on August 16, 2011 at 7:21pm
Comment by Dr Mike Black on August 16, 2011 at 10:54pm HI Sean,
Chris is right, Ublox or similar helical antenna, must be vertical, or perpendicular to the sky, this is very important.
So you need to change that, even if the antenna exits the box through a hole(un obstructed view of the sky also important)
Ok, i dont feel its right to bandy money about on this forum, but.
I need a DXF/PLT of just the parts to give you an accurate cost, but in real terms....not much..
shipping to US for summet like that, about £4, as the machines run at 55meters a minute (and we charge by the minute), material costs are very low, a few quid at most. As this is a personal offer i would do it cost anway
So, if you want me to accuratley cost it for you, please let me have a DXF or similar with scaling.
Something worth thinking about is coloured acrylics, more expensive material, but weight for strength, this would look VERY cool as a 'homage' to DIYd
VERY nice SW work by the way....
I use a similar method for prototyping, here is a small preview.
Let me know.
regards,
Mike.
Comment by Sean Skirvin on August 17, 2011 at 12:58pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.207 members
24 members
1355 members
52 members
719 members
Powered by
