Sometimes APM development goes fast, and sometimes it goes like molasses in winter. After being asked repeatedly (over many months - sorry) I have finally gotten support for multiple aileron channels in place. You can use this if you want to set your airframe up with differential ailerons or if you have separate servos on your ailerons and they don't move opposite directions for a given input.
The big delay with this change was coordinating the way we would use channels 5-8 for a variety of purposes. Functionality is coming for flaps, camera mounts and more.
Here are the things to know about using the new dual aileron functionality:
JPH - If I understand your question correctly, you need to set the reversing parameter (through the GCS) for the second aileron channel. The value is either 1 or -1. If your travel is backwards under FBW, set it to the other value.
Comment by Jean-Philippe Hell on September 13, 2011 at 10:48am This is it, Doug, but I already tried to change the value through the QGroundControl (I am under Linux / Ubuntu), but after lot of different tries (transmit, write to rom, reset the APM in different orders) I doesn't work.
Another interesting thing, I can change the RC5_FUNCT value, and after a "simple" transmit button click, the behaviour of the channel 5 is affected, so the attribution of this parameter, as the setting of the MIN MAX TRIM value of all the channels work well via the MAVlink protocol.
So I took a look in the APM code, and I saw in the function "static void update_servo_switches()", in the "control_modes.pde" file at the line 47 a comment who say that when the SWITCH_ENABLE option is set to 0, it means that the EEPROM control of all channel reversal is enabled. But I don't know if this feature is implemented yet ?
When the SWITCH_ENABLE parameter is set to 1, the dip switch reversing work well, but only for the channel 1 with the ROLL switch.
Thank you for your help, and you do an amazing job with this wonderful ArduPilot Mega !
I will continue to look in the source to resolve my setting problem.
JPH - I hate to defer you, but we have just changed the way that channels 5-8 are handled. I dont' really want to debug what we just moved away from.... A new team member (Amilcar) has just changed our RC channel library to extend a child class for the "auxilliary" channels. It will make integration of camera mounts, etc. much cleaner. I believe his changes are checked in to the repository, but probably are not yet in the latest Planner download code. The setup will change slightly, and has not been documented yet.
I will try to double check that the channel reversing is working properly with the new code and get some documentation in place this week.
The switch-enable stuff is working, but only applies to channels 1-3. If you are using stuff on higher channels I recommend disabling switch_enable and doing all of your reversing through the parameters to avoid confusion.
Comment by Jean-Philippe Hell on September 14, 2011 at 11:17am There are no problems Doug, I understand that you don't want to debug what will move in another class. I will check my version to be sure that I have the lastest release.
Anyway, I wanted to look how this project work, to have a view of the whole set of classes, etc...
I will continue my settings through the parameters. Thx for your fast answers !
Comment by Franco Marinelli on September 20, 2011 at 10:27am please could you explain me how new fuctions works? because Im trying to shoot my camera through DO SET SERVO action but I can´t!
I Set: "Do set servo" Function , servo nº5, PWM: 1698 (to shoot camera) and 1390 (to shoot it off).
But I can´t get it work!
what value must i set in : RC5_FUNCT, RC5_MAX, RC5_MIN, RC5_REV, RC5_TRIM ???????
Comment by Martin Bellomo on June 19, 2012 at 6:56am Doug, do you have any news on flaperons ? i can´t set this function properly under FBW or Auto modes
THANKS
Comment
1286 members
679 members
51 members
39 members
Powered by
