Comment by jaron on May 30, 2011 at 11:05am Hi Natha, no you can't upload the actual ArduPilot software and test it with UAV Playground.
Comment by Bur on June 25, 2012 at 9:27pm Hi Jaron, I can't command the Flightgear via another machine (data receive is ok).
Sould I have to code something?
Comment by jaron on June 27, 2012 at 9:23am Hi Bur, it is possible to run FlightGear on a different machine than UAVsim. Therefore you've got to set the IP addresses in those two files:
FlightGearSender.java
DEFAULT_IP = "127.0.0.1";
Replace 127.0.0.1 with the IP address of your FlightGear machine.
Start-FlightGear-UAVsim.bat
"--nmea=socket,out,5,127.0.0.1,5557,tcp" ^
"--generic=socket,out,10,127.0.0.1,5555,tcp,UAVsim-Protocol" ^
Replace 127.0.0.1 with the IP address of your UAVsim machine.
Comment by Bur on July 1, 2012 at 9:45pm Hi Jaron, I changed the ip you said but I still can not command the FG via UAVPlayground in another machine.
I don't know how to do. Could you please help me?
Comment by jaron on July 2, 2012 at 11:46pm Did you recompile UAVsim?
Are the IP ports open on you firewall?
Comment by Bur on July 2, 2012 at 11:50pm Hi Jaron, thanks for your kindness.
I'm now can sent the command to FG via another machine already and everything works well.
I hope we will share the knowledge about FG and the comm.sys. again later.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.691 members
87 members
51 members
7 members
131 members
Powered by
