It is a folding 6 rotor helicopter, inspired in X6 helicopter.
i would like to build in polyethylene technical plastic, it is light, shock resistant and easy to work with my cnc mill.
propellers are in a circle of 500mm diameter, i think best option in order to use standard RC parts is to use 6 x 12" counter rotating propellers.
3 (counter rotating) propeller of 12" have an 8% more surface than 4 propellers of 10" (like typical quadrotors)
Probably 14" propellers are better in order to get more performance but i think is not possible to find very low Kv motors with the necessary low power and low weight.
Any idea are welcome!
jlcortex
nmine.com
Comment by Stefano on March 4, 2009 at 10:47am
Hola Jose,
perhaps a silly question: are you planning to use the folding arm to actively control the trim of your heli or are they just for transportation purpose?
Thx
Stefano
Comment by Jose Luis Cortes on March 4, 2009 at 10:58am
Hi Stefano, no!, arms are not controlled!, only for transportation
jlcortex
nMine.com
Comment by Peter Seddon on March 4, 2009 at 11:16am
Using an even number of motors (especially 4 or 8) it is easy to see how to control such a 'copter as they work in pairs and counter rotate. I have a problem with 6motors. Can you tell me how you control pitch, yaw and roll?
Peter
Comment by xemone on March 6, 2009 at 4:01pm
Yeah this does remind me of the X6 but it's better because the camera design seems to be integrated into the airframe vs. hanging from the underside. I read this thread http://diydrones.com/profiles/blogs/bidireccional-rc-transmitter?id=705844%3ABlogPost%3A61548&page=1 and I think both your idea and the other could greatly compliment each other. What do you think?
I wrote this in another thread
I wish guys like you (guys with the technical know how) could work together, design and build a modular UAV. Have the MCU/DSP and all the sensors on the main board. Have the motor controllers separate from the main board so anyone can use different size motors (scalability). One can build a 10inch wide quad or tri- rotor or a 3 or 4 foot wide version.
Another option is a board with everything except the MCU/DSP/CPU board. This should include the sensors, servo controllers, FPGA et.c that can be controlled over USB by a gumstix module or some other powerful module (or even a pico ITX motherboard). Coupled with a controller like your idea. Anyone can make anything out of it. I'm sure the software developers out here can cook up something modular to handle all the stuff.
What d''you guys think?
Comment by Thomas Bögel on March 7, 2009 at 3:51am
@xemone:
But there already is such a system (more than one, in fact):
Both the Mikrokopter and the Armokopter consist of one PCB for sensors and controller, and have separate BLCs (in case of the Armokopter even off-the-shelf china BLCs that have to be reprogrammed, though). They both go all the way including compas and GPS (if you want), have telemetry downlink and i.e. GPS waypoint uplink. The MK supports up to 8, the Armo up to 12 (or 16?) motor concepts.
Frames are modular also (for some reason I tend to recommend the Bogoframes... but there are also others, like Q4 and Powerframe), with one core module and arms in different lengths.
Comment by marc dreffke on June 7, 2009 at 10:28am
How is this project going so far?
Comment by Thomas Bögel on June 7, 2009 at 1:27pm
Well, mine is finished ad flies great so far. I do need to fiddle with the parameters a bit, and GPS is not installed yet (I need do calibrate the compass again and did not have the time do to so yet - due to bad weather mostly).
Comment by Jose Luis Cortes on June 7, 2009 at 1:35pm
It is great!!! which controller are you using?
Comment by Thomas Bögel on June 7, 2009 at 1:36pm
As you can see, I didn't quite follow Jose's design. I do have some experience with sheet material frames, and this size would mean that there is a substantial amount of vibration from the motors.
So I went with the standard centerplates -and-aluminium approach.
The milled parts where done by a friend. The glowing stuff is basically makrolon (polycarbonate) with those self adhesive LED stripes inside.
As for the technical data:
Mass: 980g (1100g including the camera)
Akku: 3s 2300mAh 10C Wanma (Hellpower)
Hovering current: ~13A
Hovering power: 133W ohne Kamera (about 7,5g/W - 10g/W is my goal)
Motors: 3x AHM 23-10 0,47mm² wire on top and 3x AHM 23-10 0,53mm² at the bottom
Camera: Pentax Optio S7. This can be triggered using an IR-LED
Frame: Y6 Fold-Down by Dukedolphin (thank's, Duke!)
Cameramount: by PhilSU
Takedown or build-up takes well under 30seconds - it is just 3 screws plus the plug-in antenna.
Hook up the battery and go.
Comment by Thomas Bögel on June 7, 2009 at 1:40pm
Oh, almost forgot:
I am using the Armokopter board on this one.
BLCs are from hobbycity. I won't use those again - they are cheap ($13 each), but quite pooly done. One needs to remove the BEC-parts and reroute 2 signals to the Atmel. I did 8 so far, and I have a bout 1.5oz worth of surplus solder!
Comment
