Comment by Michal on September 6, 2011 at 1:45pm Negative swept wing means it hardly go to stall. Look at similar concept of Alulah glider. Wladimirze - czy latasz gdzies w okolicach Warszawy?
Greetz
Michal
Comment by Vladimir "Lazy" Khudyakov on September 6, 2011 at 10:47pm Tak jest, Michale.
Zwalić to coś w korkociąg - nierealnie.
Niestety, w tej chwili nawet nie mieszkam w Warszawie...
Comment by bGatti on September 7, 2011 at 9:03am eduardo,
the absence of a vertical stabilizer is I think for the most part intended to clean up the plane for landing (fewer parts to catch and break).
every wing system needs two components for lift: a main inclined plane, and an adjustable inclined plane to control the angle of attack.
In this design, the two are combined - which arguably increases drag - because the control surface (stabilizer) doesn't have the mechanical advantage of leverage - it has to produce more drag per unit of rotational force.
On the flipside, it does not have a separate wingtip vortex - so that helps.
Highly efficient planes (gliders) have tailfeathers on a long boom; high speed planes often shorten the leverage or merge the controls all together.
Comment by eduardo on September 8, 2011 at 8:14am thank you bGatti
i will make some tests with this design
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
185 members
51 members
136 members
24 members
Powered by
