this is a wonderful counter rotating BLDC motor and prop set ideally suited for planes between easystar and skywalker because of small footprint for the power equivalent 30xx size motors. it delivers 270 watts with 3S Lipo. the mounting would be bit tricky though. never tried but would order soon. very useful because prop diameter has to be restricted on pusher prop aircrafts with tail boom below the prop. once i get mine would put the performance parameters on the same blog. available at http://www.rcecho.com/aeo-model-1550kv-contra-rotating-brushless-mo...
Comment by apocolipse on October 24, 2011 at 11:23pm Wouldn't you need a Pusher specific variant of this? Looks like you'd need to either manually flip the props and make separate/new housings, or get a whole different version, the one pictured is a puller.
I don't know why, but i must have one. :-) Maybe because of the sheer looks of it...
Now if they would just release an ArduCopter version.................:)
Regards
Martin
Comment by Ravi on October 25, 2011 at 3:14am
Comment by Sebastian on October 25, 2011 at 7:10am I bought this motor about a year ago for a scratch built plane. It gave it a nice look worked well enough for what I wanted but the quality was a little lacking. The biggest issue were the small gauge wires that eventually just broke. They almost seemed to small for the current running through them. Just a heads up.
However, even with its faults it was enjoyable to see it run. :)
Comment by Scott Plunkett on October 25, 2011 at 7:38am Looks fun, I would love to see the real world performance specs when you get it tested!
Comment by Daniel Hibben on October 25, 2011 at 6:19pm i like this motor but the website does not say if it needs 1 or two ESC's i am assuming it needs two, but can anyone confirm this for me?
Comment by Ravi on October 26, 2011 at 12:44am It needs only one ESC. both the motors are internally wired so that they both rotate in opposite direction with one ESC. i think a simple but a brilliant idea by the designer.
Comment by Daniel Hibben on October 26, 2011 at 7:55am very cool, very cool
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.118 members
4 members
682 members
51 members
24 members
Powered by
