Arducopter with Xaircraft X650 value frame
I've been looking around for a cool frame and came across the X650 V4 frame from Xaircraft.
Before I ordered it from BDpowers I did some homework concerning were I would put all the hardware.
The frame has space for the ESC's just next to the motors so I wanted to be certain that my ESC's would fit. I managed to putin them in the tight space but using the X650 ESC covers wasn't possible. Putteing the ESC's under the props keep them very cool. Also the distance between motor and ESC is kept to aminimum. EMI from powerlines will also be reduced this way. I also looked at the center plate that would hold the APM and IMU. It fits nicely and all connectors are accessable. The folding arms of this frame was a bonus.
The current setup are :
KDA 20-22L
APC 10x4.7
Plush 30 A
Motor to motor is 60cm
Currently I'm doing tests with the latest v49 code and the first couple of flight (excl gps and sonar) were very promising.
I would like to upgrade to avroto motors 2814 and perhaps a bigger 11" prop.
Suggestions welcome.
Comment by Norman Sanchez on January 25, 2012 at 10:00am
There are imitations of xaircraf v4 and order this model
Comment by Vincent Mees on January 25, 2012 at 10:02am
@ Jack, very nice.
What props are those?
Comment by Jack on January 25, 2012 at 10:41am
The props are APC 10-47. I have changed to 10-38 to get the motor a little more efichient as these motors are a little high KV there 920. Also a smaller prop turning at a higher rpm is less efected buy wind.
Comment by Jason Wise on April 16, 2012 at 5:34am
what diameter are the arms for the X650? can I change the length?
Comment by Norman Sanchez on April 16, 2012 at 7:14am
frame arm has a diameter of 12.5 mm, can be extended longer about acquiring theXAircraft has a diameter of 55cm from engine to engine and folding 61 cm
Comment
