I've been playing with ArduPlane for quite a while and have finally got to the point where I can make it do something useful. I've been inspired by others on this site to use it for aerial photography to make 3D maps and the like.
I have an ST Models Discovery as the airframe (awesome platform for Arduplane by the way) and have made my own camera mount out of plywood for the bottom. It has one servo for roll stabilisation using CHAN 8 on the autopilot to keep the camera pointing down. It's basic but works pretty well (see pics)
Last weekend I flew over a small island on the river near my house. I managed to get 155 photos in around 10 mins and produce quite a reasonable 3d surface using hypr3d. I gotta say that these guys rock with great personal service and it's all free! They did struggle a bit with that many photos, but you can see the result below
3D Rotatable version
I'm not in the same league as some of the other makers of aerial maps on this site, and have no idea of the accuracy of this map, but was pretty happy with the early results and would like to work on this more to get better results.
my setup is
Airframe - ST Models Discovery Trainer with stock motor and 30A ESC
Arduplane 2.24 with Magnetometer, airspeed kit and xbee - a few lines of code added to output roll stabilisation
Home made camera mount with roll stabiliser
Canon IXUS 50 camera 5MP (this is a very light P&S camera) running CHDK
Spektrum DX 7 2.4GHz tx/rx
2200 mAh 3s motor battery + 1000 mAh 2s battery to power all other electronics via a UBEC (the stock BEC is too small)
I used Mark Willis's aerial coverage spreadsheet to calculate the waypoints before launch and it seemed to produce a good result.You can see the waypoint in the following screenshot
Cheers
James
Comment by Michael Oborne on November 1, 2011 at 5:20pm
I will be adding this screen to the next planner version (might be a bit away). its all working and should provide some numbers to use in the "grid" option of the planner.
Comment by Michael Oborne on November 1, 2011 at 5:21pm
Tom, do you plan on offering and offline version?
Comment by Gary Mortimer on November 1, 2011 at 5:48pm
Top question, Michael, it won't well for me when I am in Africa!
Comment by James masterman on November 1, 2011 at 6:43pm
@Nick - I will try to make it to a PerthUAV meeting. Good to see there are quite a few others doing this locally.
@Micheal - Nice work on the camera dialog. How will you choose the coverage area on screen?
@Tom, thanks for the feedback on your service. As far as aerial mapping goes, you would probably need to add a few things to make it really useful for that kind of work. There are high-end, expensive services like Pix4D already in this space, but there is always room for more.
You would need to add things like an estimation of accuracy, orthorectification and use of control points to scale the image to real world coordinates. You would also need to scale up to deal with several hundred images at once. If you can get all of that to work you could probably charge in the order of a few thousand dollars for an aerial survey result.
There is also emerging demand for data fusion, combining results of photogrammetry with LIDAR scans and other data sources to improve accuracy.
A typical mining company here in Western Australia would routinely (quarterly) get aerial flyovers of their mines by a full sized Cessna. The accuracy for this kind of work needs to be ~5-10cm so a combination of LIDAR, photos and control points is used. A lot of this data is used for estimating stockpile volumes, mining limits and the like so needs to be accurate.
I know nothing about 3D printing, so that may be a better choice that doesn't require such complexity.
I hope you do well.
Comment by Gustav Kuhn on November 2, 2011 at 2:00am
I have to concur on the airframe, flying the same here :-)
James, pry off the cowl, remove the weights stuck therein, and you can use a bigger battery !
Comment by Chivar Maximillan Pilones on November 2, 2011 at 2:02am
simply great! if its only possible if this could be included as an out of the box function with the gcs/planner :) ]
Comment by Michael Oborne on November 2, 2011 at 2:52am
have you guys used the grid funtion in the planner? this is what its there for.
in flight planner
right click goto grid > add polygon point
repeat above untill you have your surround, allow extra.
next click grid
specify your flying alt.
specify the distance between lines , eg in picture above i would use 172 which has 30 % side overlap
the next part is to fire the camera at 73m intervals, or via time delay... etc etc.
i know personaly i use the relay on a constant 4 second timer.
Comment by James masterman on November 2, 2011 at 3:31am
Thanks Michael, the grid function appears to do nearly everything I need for setting up waypoints for aerial photography runs. The only addition needed is to calculate grid spacing based on camera parameters.
@Gustav - thanks for the tip, I didn't realise there were weights in the nose. The cowl is not easy to remove so it's hard to tell what is in there!
Comment by Gustav Kuhn on November 2, 2011 at 5:42am
Tell me....
I bent the motor mount, after my plane flew into a hill on auto, you need to cut the nose sticker, then gently pry away one side first.
Afterwards, just stick some pvc tape over the joint.
( Didn't visually track the plane during the incident, so I used the log file to find the last point of data, then drove around the area 'till I picked up the xbee signal again, got a google earth picture of it's exact position :-))
Comment by Gary Mortimer on November 2, 2011 at 5:56am
@Mike that made me download the GCS right away and consider joining the Ardu clan! I will watch out.
Comment
