In case you're looking for an optical flow sensor, there is now one available in the DIYDrones store for a penny under $40.
This sensor is based on the ADNS3080 mouse sensor which is a good choice for optical flow because:
high resolution: 30 x 30 pixel frames meaning it can see features that lesser mice cannot
high speed: 2000 to 6400 frames per second update rate which contributes to better low light performance than other mouse sensors
SPI interface meaning it can be interfaced to many micro controllers and co-exist with other sensors
Other features:
Instructions for connecting the sensor to your APM/Oilpan are here.
Things to be careful of:
Uses including odometry and obstacle avoidance but I've used it mostly for horizontal position hold.
Note: integration with ACM and the existing GPS pos hold is a work-in-progress but should hopefully be completed in a few weeks. Here is a video of a slightly modified version of the ACM code using only optical flow (and sonar for altitude hold).
Inspiration and some technical help especially early on came from Marko Klein Berkenbusch and his blog on position hold with mouse sensor.
Hope you like it, all comments welcome!
@Andrew: I think the compensation is done via the attitude estimate from the IMU (which is know to the quad anyways). It is not as hard as it may seem - look at Randy's instructions he linked.
Comment by Andrew Radford on November 21, 2011 at 9:53am Ok - I suppose the 'hard' bit would be that there is error from the flow sensor, error from the IMU attitude, and I suppose you would also need altitude also? so error from the sonar. The maths I suppose is easy - was just wondering how coping with all the error plays out in practice.
It is very cool though and look forward to equipping my quad with one!
@IS we plan to start shipping the optical flow sensors from our store in a few days,
@Randy and UT: Thanks for your answers.
I suppose sonar is compulsory, isn't it?
Comment by ThomasB on November 21, 2011 at 11:45am The eagle file shop link seems to have some problems (at least with me) :(
Comment by Ellison Chan on November 21, 2011 at 12:01pm Wow, I didn't see the link to the files, but looks like either they're not on the server yet, or there's an SSL server error.
@Ellison,
I'll check-up on the eagle files with Lorenzo & Sam.
@Andrew,
You're right about the error being a concern and it can cause some bad behaviour like drifting. The size of the feedback from the sensor for a given horizontal movement increases linearly with the altitude so having the altitude measurement off by 10% will lead to the calculated distance also being off by 10%. Still, if it was consistently off by 10% and you were just doing position hold it would be ok.
I suspect timing differences between the IMU attitude measurements and the flow sensor measurements can also let some error in....and then there's the field-of-view constant, get that too low and the position algorithm will overestimate the roll/pitch compensation leading to a bad case of the wobbles! Still this last one you probably don't need to worry about because I believe I've got it pretty close now.
@I.S.
I've always used a sonar because it gives much more accurate altitude information. The barometer's got that "random walk" type behaviour which I suspect will cause a lot of trouble at low altitude which is probably where the optflow sensor is most useful.
Comment by Ryan C Smith on November 21, 2011 at 5:41pm @Randy Is it possible to use more then one? One for obstacle avoidance and one for alt hold? Or 4 all the way around for obstacle avoidance and one for al hold?
I don't think it matters that much if they're exactly on the same plane at least for position hold. Little spikes in the altitude like the sonar can produce aren't good so try and get rid of those if possible.
Now if you were trying to use it to control absolute position in a gps denied environment...then you'll need to spend time on getting the altitude as accurate as possible. Now if you're trying to do that, important to note that a mouse sensor can't sense rotational movement so try and avoid doing that too much (of course a quad can move in any direction so maybe you don't need to yaw anyway!).
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.207 members
58 members
24 members
1355 members
88 members
Powered by
