APM 2.0 is the culmination of almost a year of hard work. We wanted to make it perfect and we finally have it, we are pushing the limits of AVR and Arduino. I’m sure you will love it, and it’s designed to cover all the DIY community expectations (including those that are not so DIY and are only interested for something that doesn’t require soldering skills).
Check the product listing for availability status!
Main Features
New sensors
The big advance in APM 2.0 is the introduction of the Invensense MPU-6000 sensors, which have an internal Digital Motion Processor (DMP) that does advanced sensor fusion. We’ve tested it for months, including lots of flying, and it significantly outperforms the DCM used in APM 1.0. It’s your choice whether you want to use the MPU-6000 internal sensor fusion or do it yourself in the main processor, but if you choose the DMP it frees up nearly 40% of the processing power in the Atmega 2560. This is a digital chip, so we were able to eliminate the ADC chip used in APM 1.0, lowering chip count along with cost and size.
We’ve also upgraded the barometric pressure sensor to the MEAS MS5011, which has a resolution of 10cm! This is at least twice as accurate as the pressure sensor on APM 1.0 and should give ArduCopter best-of-class altitude hold capability. Here are some of our side by side tests conducted by Jose Julio (Spain):
We joke about the color of APM 2.0, we say that is the fusion of ArduPilotMega V1.x (Red board) and the Oilpan/Sensor Shield (Blue board) and resulted to be a purple board. Well this might not be the real reason of the purple color, in fact the APM 2.0 fuses the APM 1.0 and the Oilpan/Sensor board into one, in order to save space and make it cheaper.
Micro daughterboard
But why does it have a small daughterboard with an SD slot, GPS and the magnetometer on top? Aha! The big dilemma I had for months! I was very concerned about leaving the GPS and the Compass stacked on the main board. What will happen to the compass if the board is placed near to big electromagnetic fields like a brushless motor? What will happen if the board is inside a carbon fiber frame and GPS reception is blocked? But what happen if none of those issues matters to you and you want a small board with everything on it? What can I do to solve the necessities of everybody?
So I developed a small shield that can be mounted inside the boundaries of the pins and has special connectors to keep a very low profile of the system, so if you want a small board then you have it! But this shield is optional, so you can still attach your old GPS by using the standard APM V1.0 GPS connector or the classic compass port. But because I promised no soldering I have created a special I2C port (similar to the GPS) that allows you to attach an official APM 2.0 Compass board by just plugging it (yeah just plug and play). The SD slot is there because I had no other place with easy access (underneath the main board was messy and you will be obligated to dismount and flip the entire board to remove the card, you don’t want that right?). In the other hand the daughter board will come in four flavors: GPS+MAG+SD, GPS+SD, MAG+SD and SD. For example if you want to attach only the magnetometer (Compass) externally you just buy the option GPS+SD.
SD card dataflash
The SD slot can read regular SD cards. But for the moment we don’t use them in ArduPlane or Arducopter code because writing regular FAT tables is very slow and can screw up the main loop refresh rate (We’re not using a RTOS yet, and won’t until we migrate to ARM in Q1 next year). There’s why I have created a custom SD card with dataflash on it (twice the capacity of the one in APM 1.0), plus it has the advantage of being removable so you can have multiple logs or you can easily replace it when you exceed the life of the chip. But in case you are planning to use APM 2.0 in something that doesn’t require a 200Hz loops (like a very powerful data logger or weather station) you can interface with a regular SD cards and write text files on them. The possibilities are endless!
The board itself is our first four-layer design and is smaller than APM 1.0 (believe it or not it’s just 2.6 x 1.6 inches, even smaller than the UDB) and this includes four mounting holes and rounded edges to give a nicer look and feel! Of course it’s lead free and ROHS complaint.
New PPM encoder and USB interface
Along with the Atmega2560, there is an Atmega32-U2 that works as the USB (FTDI) serial programmer (Arduino Compatible) and PPM Encoder. This setup allowed us to save even more space and reduce prices by eliminating the FTDI chip in the APM 1.0 board. Best of all, you can update the Atmega32-U2 firmware without buying a SPI programmer; you can easily update via USB!
The Atmega32-U2 also features something called “Serial0 Auto Switch”. This function automatically toggles the serial port 0 from the Atmega2560 from the USB Serial programmer and the modem/OSD port. When you are about to upload a new code through the mission planner or Arduino the Atmega32-U2 will auto-route the Serial0 to the USB Com port and load the code, when is done it will automatically switch it back to the Modem or OSD port. This maximize the usage of this serial port that before was wasted the average of the time (not used while flying). On the APM 1.0 the modem won’t work when is programming and you don’t program anything while you are flying so theirs is virtually no downsides in normal operations. Anyway in case you want a dedicated UART for each you can still switch back to the old APM 1.0 configuration with some solder jumpers.
More I/O
APM 2.0 is also packed with 12 analog pins that can be used as digital I/O pins and three of them can be “solder jumpered” to add extra PWM output channels (for gimbal operations). Each analog/digital pins can be used to read or control special devices like current, RPM, voltage and ultrasonic sensors and output devices like cameras and relay’s. The mission planner will allow you to define in which pins you have connected a device and a drop box will give you the options to select pre-defined sensors or declare a new one (Something similar to Remzibi OSD). This sensors or output devices can be later used in missions and do actions when certain conditions are met (Not implemented yet).
APM 2.0 features 8 PWM outputs (and can be increased to 11 if you give up 3 of your 12 analogs) and 8 PWM inputs. You can also bypass one of the pins with a solder jumper to insert your own PPM signal, still you can use the other PWM inputs left to control something else (so you can have more than 8 inputs).
The +5V servo power is optionally separated from the rest of the board, you can join both powers by insert a regular jumpers. This saves us a lot of problem in some setups. It also features a protection diode to protect the board from reverse polarities. Reset pins are left exposed with ground, so you can add an external reset switch if you wish.
Thanks to the incredible work of the DIY Drones Dev Team, the ArduPlane and ArduCopter code will support the APM 2.0 board when it ships. Special thanks to Pat Hickey, an embedded programmer rock-star, who led the team who ported the code to the new board. Others who worked tirelessly on this include Jose Julio, Andrew Tridgell, Doug Weibel., Randy MacKay, Jason Short, John Arne Birkeland, Olivier Adler, Sandro Benigno, Max Levine the 3DRobotics team and scores of others. It was a huge job!
Special thanks to Chris Anderson for making this possible.
The new code is already in the repository and supports both APM 1.0 and APM 2.0. The Mission Planner will autodetect your board and load the appropriate code (Note: the official 3D Robotics APM 2.0 board has a unique signature and the MP will look for that. Other people can make their own APM 2.0 boards, but the official MP will probably not support them). But if you want to do it manually in Arduino just change this line in Config.h from APM1 to APM2: # define CONFIG_APM_HARDWARE APM_HARDWARE_APM1
APM 1.0 (back) vs APM 2.0 (front)
Price
As you can see the board is more than great! But when you discover the prices you will be double amazed:
APM 2.0 + Daughter board (with all sensors) + 1 x dataflash Card for datalogging + USB micro cable + All pre-soldered and tested for just $399… But we have a special DIYDrones promotion; if you buy it within the next 100 years you only will pay $199.95 (yeah you read it right $199 US Dollars). =P
Seriously. $199 for everything, for everyone, always.
Important note: The board is already available and tested, but with this incredible price you can expect a very high demand (even before formal announcement) so the only way you will be able to get one board soon is by pre-order at the link below. The expected waiting time is from 1 to 6 weeks. First come, first served. We expect to end this delay by February when the shortage of some sensors is over. (We’re going to limit the first batches of board to users; unfortunately we can’t allow distributor sales until customer pre-orders are filled)
Comments are closed for this blog post
Comment by Stafford Brunk on December 1, 2011 at 2:51pm I suppose so. I'm already using an adapter board on two frames so I'd just have to make another.
What is going to happen with the switch to ARM next year? Will this board be deprecated?
This is an innovation community which should be used to the fact that technolgy is ever maturing and that we should never grow that attached to any one step in the process. (or in your case, a particular form factor)
Comment by Juan Carlos Hdez on December 1, 2011 at 3:39pm Impressive!!
impressive. We are proud with you.
Comment by Stafford Brunk on December 1, 2011 at 3:50pm Sgt Ric: I will respectfully disagree. I believe you are confusing maturing technology with a change in board footprint. I do not take issue with the costs of the new board, I dislike the footprint change. Nothing about the current board footprint stifles improvements. The existing mounting holes on the APM do not stretch the width of the board. Since this new board appears be narrower, I wonder why the mounting holes were not made to line up. You could still shrink the APM while keeping the mounting holes the same. This would ensure compatibility with everyone who already uses an APM (many people still run a 1280 APM). IMO, it would make more sense to make drastic changes to the board footprint next year when the move to ARM is done. Since that is a drastic architecture change anyhow, complete backwards compatibility can be broken.
A lot of people on here fly multiple frames, many of which are custom. For example, I have a unibody carbon fiber frame I made to fly a small arducopter with 5" props. The weight cost of adding an adapter board will be detrimental to performance (which may well be compensated by smaller hardware, without details I don't know) but I am not sure the frame will be easily adapted to the new footprint.
The issue is moot for me. I already placed an order for two. I'll make the necessary adapters for my two larger frames and wait and see on the CF one.
Comment by Paul Feely on December 1, 2011 at 3:56pm Smaller the better for me:) I'd like to squeeze arduplane into my multiplex merlin. hope they arrive for xmas holidays!!
Comment by Tomas Soedergren on December 1, 2011 at 4:23pm Just placed my order :)
One thought about the baro sensor; will it be possible to attach like a silicone tupe to connect to static port at a dedicated location on the vessel. Due to aerodynamic phenomenas the board might not be the best spot to get clean measurements.
Anyway, congratulations! Great achievment!
Seems nice, could be for Chrismas. Someone has ordered it for me!!
Narrower board will fit inside 450 heli frame, APM 1.0 was slightly too wide to fit without modification of frame. Inputs on one end and outputs on other, seems nice. Smaller is good!
Having the gps, mag and sdcard slot on the small board, yes could put on a cable to mount elsewhere, maybe out on a tail boom. The daughterboard looks not much larger than gps adapterboard.
I wonder if the gps serial port lines have a level shifter, so that the 3.3v gps will communicate robustly with the 5v 2560, regardless of slightly higher 5v supply. Could be just 2 or 3 discrete components on the tx line from gps on daughterboard, I think? But, I suppose a fine solution is keeping 5v not above 5v.
@Tomas, probably the baro sensor is I2C, could get another one, have a daughterboard for it and put it elsewhere. But the sensor looks like not a large enough form factor for a tube fitting port.
Comment by Duy Pham on December 1, 2011 at 5:17pm The new board looks very cool but the GPS module should be separated so we can put it any where outside.
I expected a version of ARM Cortex MPU and this is still with AVR
How many orders so far ?!?! How about a preorder counter on the store page, that would be fun.
Duy: If you read the post you'll see that you can connect an external GPS or buy a version without the GPS on the daughterboard. Also, as we've said countless times, we're releasing the ARM Cortex version to developers when Arduino does, in Q1 next year.
203 members
720 members
1355 members
207 members
Powered by
