as it was kind o difficult to me setting up flight modes on APM the way Gordon discribed, I tried to find an easyer way (but still Gordon did a good job and my way based on his...)
Big THX to apocolipse, as I forgot to write which firmware I`m using. It`s the er9x (lates trunk)
I show on an examples, as it is real easy. What I did is to use the custom switches 1 to 6 (csw1 - csw6) and the mixers.
Goto to mixer and add a line with the setting (in my case ch8 but it`s up to u, which ch u use)
CH08 100% MAX SWITCH (SW1)
100% MAX SWITCH (SW2)
100% MAX SWITCH (SW3)
100% MAX SWITCH (SW4)
and so on....
Ok, now I go to Switches an assign the following values to SW1:
CSW1 function: and / value1:ID0 / value2: !AIL (if u`re not use to, ! means not active)
CSW2 function: and / value1:ID1 / value2: !AIL
CSW3 function: and / value1:ID2 / value2: !AIL
CSW4 function: and / value1:ID0 / value2: AIL
CSW4 function: and / value1:ID1 / value2: AIL
CSW4 function: and / value1:ID2 / value2: AIL
Now you hook up APM in cli mode, going to pwm test. Taking the radio and adjusting the 100% value on SW1 so, that I get the recommended 1165 for normal mode (in my case: CH08 / -65% / MAX / SWITCH(SW1).
Do this to all mixers.
Then I set the modes, like shown on diy google codepage.
That`s it.
c u in da sky
Looks good. I've added it to the manual here.
Comment by Chris on June 1, 2012 at 6:36am I just wanted to point out a few things in these instructions to save future people grief. While this does work well, there are some things to point our that are different with the current ER9X firmware.
Comment
1283 members
676 members
4 members
8 members
Powered by
