New wing from Skywalker factory >>X8 UAV platform
For those who want Long range / Long flying time / High payload the new X8 wing will get you there..
The wing X8, will be released early 2012.
Wing span: 2122mm
Wing area: 80dm2
valid payload: 1000-2000g
X8 use KV730 2820 Motor, 40-60A ESC and 1260, 1280 prop
X8 skywalker wing
I'm already in love with this bird...
Now the X8 wing is ready in strong EPO foam
Tags: UAV, big, wing, x8
Comment by Ace on April 11, 2012 at 8:31am
I covered mine with corbon vinyl:
Now I'm busy fitting it all in APM1 and FPV.
Comment by BriFly on May 4, 2012 at 10:54am
So I am trying to gather the equipment needed for my X8 and wanted to find out what the recommended Motor, ESC, and Prop would be for a 3S setup???
Thanks!
Comment by Rick Stewart on May 4, 2012 at 11:39am
@Ace, how much did the vinyl add in weight?
Rick
Comment by james sowell on May 4, 2012 at 5:44pm
http://www.rcdude.com/servlet/the-Brushless-Motors-cln-Scorpion-30m...    I went with 3020 890 kv on 4s with 12 6 just a higher kv on 3s this guy has great serv shiped mine the same day
Comment by BriFly on May 4, 2012 at 6:34pm
Thanks for the info James.  What size ESC are you using with that setup?
Comment by james sowell on May 4, 2012 at 7:11pm
castle 50 castle 10 amp bec you can go a little bigger Im trying to go with long flight time you can shoot him a email and he can hook you up but I still get my batt. from HK you can go here with X8 stuff trying to get PID setting on this site http://www.rcgroups.com/forums/showthread.php?t=1555543
Comment by Peter on May 10, 2012 at 2:20pm
X8 (last series) short maiden flight - easy job
http://youtu.be/pXchU2ArBig
Comment by Gus Fraser on May 30, 2012 at 1:36am
Mine is on order. Has anyone fitted retract gear/retract nose skid ? if so what did you fit and how did it go ?
I did see on rcgroups a guiy made a dolly for take off. I intyent to cover mine in 3m carbon vinyl any feedback on this is it a good or bad idea ?
I think that this airframe opens up a new challenge for drones. Longest X8 auto flight. Take off, cruise and landing hehe !!
I intend to run mine with an fpv camera and the camera tracking code set with an HD hero mounted in the nose with pan and tilt. I want to mees with the code a bit to create a new script element that will allow camera tracking of the active waypoint :-)
Thanks in advance.
Comment by james sowell on May 31, 2012 at 6:58am
not yet still working on missing parts and carbon strips in the wings
Comment by Hans Miller on June 16, 2012 at 6:10pm
Just received mine in the mail and I have to say there are some things I am less then impressed about:
-I ordered black EPO foam. NOT white EPO foam RESPRAYED BLACK.
-The packaging could be better. This would avoid slight damage to the tips of the wings at the trailing edges.
- Fit could be a hell of a lot better. I am going to have to trim a fair few bits of foam so the fuselage fits together.
Having said all that, I am looking forward to the build immensely.
Comment
