New wing from Skywalker factory >>X8 UAV platform
For those who want Long range / Long flying time / High payload the new X8 wing will get you there..
The wing X8, will be released early 2012.
Wing span: 2122mm
Wing area: 80dm2
valid payload: 1000-2000g
X8 use KV730 2820 Motor, 40-60A ESC and 1260, 1280 prop
I'm already in love with this bird...
Comment by Ace on April 11, 2012 at 8:31am So I am trying to gather the equipment needed for my X8 and wanted to find out what the recommended Motor, ESC, and Prop would be for a 3S setup???
Thanks!
Comment by Rick Stewart on May 4, 2012 at 11:39am @Ace, how much did the vinyl add in weight?
Rick
Comment by james sowell on May 4, 2012 at 5:44pm http://www.rcdude.com/servlet/the-Brushless-Motors-cln-Scorpion-30m... I went with 3020 890 kv on 4s with 12 6 just a higher kv on 3s this guy has great serv shiped mine the same day
Thanks for the info James. What size ESC are you using with that setup?
Comment by james sowell on May 4, 2012 at 7:11pm castle 50 castle 10 amp bec you can go a little bigger Im trying to go with long flight time you can shoot him a email and he can hook you up but I still get my batt. from HK you can go here with X8 stuff trying to get PID setting on this site http://www.rcgroups.com/forums/showthread.php?t=1555543
Comment by Peter on May 10, 2012 at 2:20pm
Comment by Gus Fraser on May 30, 2012 at 1:36am Mine is on order. Has anyone fitted retract gear/retract nose skid ? if so what did you fit and how did it go ?
I did see on rcgroups a guiy made a dolly for take off. I intyent to cover mine in 3m carbon vinyl any feedback on this is it a good or bad idea ?
I think that this airframe opens up a new challenge for drones. Longest X8 auto flight. Take off, cruise and landing hehe !!
I intend to run mine with an fpv camera and the camera tracking code set with an HD hero mounted in the nose with pan and tilt. I want to mees with the code a bit to create a new script element that will allow camera tracking of the active waypoint :-)
Thanks in advance.
Comment by james sowell on May 31, 2012 at 6:58am not yet still working on missing parts and carbon strips in the wings
Comment by Hans Miller on June 16, 2012 at 6:10pm Just received mine in the mail and I have to say there are some things I am less then impressed about:
-I ordered black EPO foam. NOT white EPO foam RESPRAYED BLACK.
-The packaging could be better. This would avoid slight damage to the tips of the wings at the trailing edges.
- Fit could be a hell of a lot better. I am going to have to trim a fair few bits of foam so the fuselage fits together.
Having said all that, I am looking forward to the build immensely.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1286 members
87 members
39 members
24 members
5 members
Powered by
