U4eake's showleds, arming and low battery warning leds
Following up on the success of my relay low battery warning leds I have expanded that code to include a complete lightshow and to be compatible with the newest ACM codes (2.1.1) and the APM1 hardware.  APM2 hardware MAY work, but I don't have APM2 at this time, so no guarantees.
Credits to Bill Sanford and Max Levine whose work has been an inspiration and a basis for these leds.
1) Software side :
By using the agmatthews userhooks it is now much simpler to upgrade to a new firmware without having to change the code each time.  You just have to copy 2 files and change setting in the APM_config.h.  The needed files AND my config.h file (for version 2.1.1r5) are in the following file : U4eake_showleds.zip
Updated files for ArduCopter 2.5 (compile with arduino1.0 relax patch) : u4-showleds.zip  These still work for ArduCopter 2.5.3.
Update files for ArduCopter 2.6 : Showleds_ACM2.6.zip  Because motors were put in a library, every motor_armed in the showleds code had to be modified to motors.armed().  Also you have to put
#define COPTER_LEDS 0
into your APM_Config.h file to disable the new copterleds, which are enabled by default.
You need to copy the usercode.pde and the usercode.h files into your arducopter directory (overwriting the files already there) and add the settings below to your APM_config.h.  DO NOT just copy my APM_config.h, it is only included as an example to clarify the settings.
#define MOTOR_LEDS 0                                   // 0 = off, 1 = on
#define SHOW_LEDS 1                                    // set to 1 to enable AN7-AN15 controlled led lightshow
#define RELAY_LEDS 0                                    // set to 1 to use the old relay led low battery warning
#define BATTERY_EVENT ENABLED
#define LOW_VOLTAGE 9.9
#define MID_VOLTAGE 10.6
#define VOLT_DIV_RATIO 3.33
#define INPUT_VOLTAGE 5.26
Also uncomment the 50hz agmatthews userhook and the mediumloop userhook (remove the // in front of it) so it looks like this :
#define USERHOOK_50HZLOOP userhook_50Hz();
#define USERHOOK_MEDIUMLOOP userhook_MediumLoop();
The voltages can be adjusted to match your desires.  If you have a 4S battery for example, you should put higher values, like 13.2V for the LOW_VOLTAGE.  INPUT_VOLTAGE is the voltage that goes into the APM (usually the voltage from you ubec).  VOLT_DIV_RATIO is an calibration value that you can adjust so that your reported battery voltage corresponds to the real battery voltage.
After compiling the code with arduino and uploading it to the APM board, you also need to set battery monitoring to option 3 : battery volts
That's it for the software modifications if you have a hexa or are happy with the patterns as they are !  On a quad or octo you may want to adjust the patterns a bit, but I'll explain that further down this blog (see Adjusting Patterns).
The code and blink patterns are optimised for use on my hexa (6 leds strips on the arms + 2 spare ones).
The leds will go on when motors are armed and out when disarmed.  During flight, different flashing patterns can be selected with Ch7. The other use of Ch7 is not affected, so you can still use it for simple or recording waypoints. The leds will flash with the last pattern in this file when ch7 is high (recording waypoint or simple)
When battery gets below the first threshold (MID_VOLTAGE = 10.6V), the ledshow is overridden and the leds will flash with following pattern : led 1,3,5 on/off and led 2,4,6 off/on. So if the first ones are off, the others are on and vice versa.
When second threshold (LOW_VOLTAGE)is reached (9.9V) the leds will flash quicker.
2) Hardware :
The code uses the AN8 tot AN15 analog ports (portK) on the oilpan of APM1.  In the picture you can see them labelled  AN0-AN15.  AN8 to AN15 are the ones on the right (4x2 pins)
You can either connect 1 led directly to each port (the ports can supply 40mA current) or you can use a ULN2803 darlington transistor chip to drive the leds according to the following shedule (thx to Max Levine for this schematic) :
This shedule is for a quad and uses a ULN2003.  The ULN2803 has 8 ports instead of 7 and if I remember correctly it can supply a little more currrent (500mA per port).  A typical hobbyking 12V ledstrip of 1m (60 leds) consumes about 300mA, so normally you should be able to hang 1m of ledstrip on each of the 8 ports.  That should be plenty !!
You can get the ULN2803 in your local electronics shop or online here : Canadadrones - ULN2803
The darlington chip lets each input control the output directly across on the other side of the chip.  So nr1 in the picture above, controls output 16,   Nr 2 controls output 15 and so on.  If you look at the pinout picture of the oilpan, you'll see that nr 1 is connected to AN8 and nr2 is connected to AN10, so AN8 in the pictures above controls the red leds, and AN10 controls the green leds.  Get it ? ;-)
After the brainsurgery it will look something like this :
Now you just have to put a heatshrink over the ULN2803 chip and tuck all the wires away nicely.
CAREFULL : in the picture above I had soldered the wires to the wrong ports (side of the compass).  That's what you get when working on your copter till 4 in the morning...  It took me a day to figure out why my leds didn't work as expected.  So you have to solder your wires on the OTHER SIDE (side of the usb connector).  I didn't have a picture of when I soldered it right.
Finally you'll also have to set up your board for battery monitoring (option 3 : total voltage) by soldering the voltage dividers and connecting battery voltage to AN0, which is explained in the wiki here :  Voltage sensors on APM1
3) Adjusting the blinking patterns
First you'll have to understand a little about bitmath in arduino : http://www.arduino.cc/playground/Code/BitMath
To save processor cycles I've opted to drive the portK of the atmega1280 using direct portmanipulation.
If the above all sounds too complicated : here's the simple explanation.
In the usercode you'll often find something like PORTK = B00101010;  This instruction actually turns leds on and off.  0 means off and 1 means on.  Each number turns 1 port off or on, and the first number after B turns port AN15 on. So the ports are B-AN15-AN14-AN13-AN12-AN11-AN10-AN9-AN8 of shorter written : BAN15...AN8
If you would now like to turn the red leds on and the others off in the picture above, this would be PORTK = B00000001; (turns AN8 on, and AN8 is connect to nr1 on the darlington, which turns on red leds)
If you wanna turn the 2 blue ledstrips on and the others off it would be PORTK = B01010000; (ports AN12 and AN14 on, which are connect through the darlington to blue leds)
All 4 strips on would be PortK = B01010101;
Ofcourse for hexa's and octo's this depends on which AN port you have soldered to which nr on the ULN2803.
Now we can turn leds on and off, but they still don't blink or "rotate".  For the blinking a counter is used and depending on the counter, leds are switched on and off.  The counter runs in the 10hz or 50hz loop, so you can time the blinking.  If counter =5 when in the 10hz loop will correspond to half a second.
For "rotating" arms I use the bitmath again, more precisely the bitshift operators and >>.  These simple shift all bit a few places.  so 00000001 1 becomes 00000010.  The 1 shifts 1 place.  By now you understood that this is an easy way to make the leds "rotate".  Just shift the B00000001 1 place each loop cycle and your 'on' leds will shift an arm each cycle, making them look asif they rotate.
4) TO DO
On the 8 port ULN2803 there are still 2 ports left unused on my hexa.  I'm planning to use those to replicate the gps status light and maybe a failsafe warning light.  I've also thought about using them to drive leds in the form of a smiley :-)  Other ideas are always welcome !
I'm using the relay now to ignite fireworks on the hexa.  But that's a story for another blog ;-)
That's about all I can think of telling you, and by now my fingers are tired and my brain is mushy.
I hope you enjoy these leds and don't scare too many people with your new UFO ;-)  Feel free to ask questions in the comments below if something is not clear.
Ow, and ofcourse I assume that you know what you're doing if you solder on your board.  I take NO responsability if something goes wrong and you break it !  Do this at your own risk !
U4
Tags: ArduCopter, ledshow, lights, motorleds, multicopter, showleds
Comment by R_Lefebvre on January 3, 2012 at 3:01pm
Nice work.  I put this one in the wiki as well.
Comment by u4eake on January 3, 2012 at 7:23pm
Thanks !!!
Distributor
Comment by Dany Thivierge on January 3, 2012 at 7:46pm
That's great post on all information in one place.
Great timing as I was creating the inventory entry for the ULN2803 product on CanadaDrones.com
http://www.canadadrones.com/ULN2803-p/uln2803.htm
I took the liberty to edit the schema image to show the 2803 instead of 2003... hope I got the pins right!
All credit given where credit is due!
Great job guys!
Dany
Comment by Max Levine on January 3, 2012 at 11:04pm
Comment by u4eake on January 4, 2012 at 5:42am
That's great Dany, now people can easily find that ULN2803.  Do you also plan to carry the 12V ledstrips in different colors and a bit of thin wire, so people can get a complete hardware package ?
The picture credit should go to Max Levine.  I just borrowed it from his blog.
Comment by Dani Saez on January 4, 2012 at 3:12pm
Nice "disco" lights!!  ;-)  well done!  I understand that if you want to use 6 or 8 strips you must use more AN outputs?  could you make a draw for an octo?
Cool work!
Comment by u4eake on January 4, 2012 at 5:49pm
HAHA, discocopter, that's a good one !
When I turn 40 I'll hang it on the ceiling and throw a party !  When it gets too hot it can act as a ceilingfan too !!
Yes, you'll have to use more AN ports for a hexa or octa.  I just soldered all 8 of them (AN8-AN15).  It's just the 4 pins on the 2nd row behind the already soldered pins in the schematic.  I'll see if I can modify the schematic when I have some more time.
Distributor
Comment by Dany Thivierge on January 5, 2012 at 8:40am
I will correct the credit! Thanks Max for updated picture!
Yes I will carry the LED Strips on my site... just waiting for my order to ship...
In 2012 CanadaDrones.com will carry a lot more parts and the Canadians will get everything in one convenient place.
As you can see I will not really make profit on these, I just want to offer a one stop place where people can find what they need and get it all shipped at the same time as their main order.
Thanks guys for making this possible.
Comment by Graham Boucher on January 7, 2012 at 10:21am
I had this all wired up nicely with my APM1,
now I'm trying to switch everything over to the new APM2 board and can't for-the-life-of-me find the pins I should be connecting to...
This WIKI page is the only info I've found regarding the APM2's available ports which gave me no idea where I should connect leds!
I've even installed Eagle Light so I could check the board schematics but couldn't see anything that helped.
Any ideas anyone?
Comment by Michael Urban on January 17, 2012 at 11:39pm
Thanks for the great instructions.
One question: Would this also work with Battery Monitor mode 4: Volts & Current - or is mode 3 absolutely mandatory?
Comment
