Getting six fly modes on Futaba T10CAG transmitter
We use for example CH5,switch C-3positions and switch D-2positions.
Settings:
1. Transmitter END POINT menu-GEAR -100%
2.SUB-TRIM menu-GEAR -0
3.AUX-CH SELECT menu –CH5-Ls1(Logical switch)
4.LOGIC SW menu.Settings as shown on left.
 5.PROG.MIX1-8 menu choose mix 5
 6.P.MIX5  page 2/2 settings as shown
7.GYRO SENSE menu settings-CH5 and switch C as shown.
 8.GYRO SENSE  menu position 2 to ON.
 9.C switch up,D switch up and set 68%.Pulse with in this set is 1166µs.
 10.C switch middle position,D switch up and set 48%.PW-1264µs.
 11.C switch down,D switch up and set 16%.PW-1423µs.
 12.P.MIX5 menu tab2/2 turn MIX ON.
 13.P.MIX5 tab1/2 C switch down,D switch down and set -(minus)71% at poin5.PW-1554µs.
 14.C switch middle,D switch down,set -(minus)76% at point1.PW-1683µs.
 15.C switch up,D switch down and set -(minus)71% at point5.PW-1814µs
 16.Now P.MIX tab2/2
That's all.There are other ways to do it,no doubt.
Comment by John Campen on June 25, 2012 at 5:06pm
yes I have all six working well and this tutorial works if you follow it by the letter
Comment by Adam Rivera on June 25, 2012 at 6:53pm
How the hell did you figure this out? :-D
Comment by Max Yeo on June 25, 2012 at 7:50pm
I did follow every steps ... but still can't get
Comment by Adam Rivera on June 25, 2012 at 7:52pm
You sure you have the same radio? I just went through this process tonight and it worked for me.
Comment by Max Yeo on June 25, 2012 at 7:56pm
Futaba 10CAP
Comment by Adam Rivera on June 25, 2012 at 7:57pm
I have the 10CAG and this post is written for the 10CAG model. There must be a difference in the 10CAP.
Comment by Max Yeo on June 25, 2012 at 7:59pm
10CAG only 2.4g 10CAP 2.4g & FM module
Comment by Wattas on June 26, 2012 at 12:46am
This is for T10CAG only.I do not have 10CAP,so can't write about settings.
Comment by John Campen on June 26, 2012 at 8:43am
Ive used this for the both the T10CAG and the T10CHG  and works fine. As I understand the difference between these two is they are  physical identical only that one is setup software wise as default for airplane and the other is set up as default for Heli. I'm not sure what defaults the 10CAP is set for, but perhaps if you download the manual for the CAG and compare where its defaults are different and maybe reset your to this as default and then start from there.
Comment by Max Yeo on June 26, 2012 at 8:45am
A=Airplane H=Heli
Comment
