So, here is my other post that I've promissed. I think this one may excite many of You. Well I'll let the picture speak here now...
This is a Samsung tablet based UAV controller. The device is intended as a replacement for a regular transmitter and will communicate directly with my all in one UAV controller elliminating a need for a regular RC transmitter, wire harness and etc. This will result with less mass and less power consumption on the airframe!
The current version can communicate with the UAV board with an xTend module, but can also be easily converted to an xBee or something else. The board inside also has a pressure sensor to provide for reference pressure readings as well as additional expansion ports for digital and analog IO's. Additionally I've added expansion microSD card slot for data logging.
Currently the tablet software supports display of all telemetry information and serves as a command center - it allows for waypoints definition and PID tunning. The picture above is an older picture that is a bit cleaner as the inside wiring is a mess. New mold for an enclousure is on the way that will allow for more organized "guts" and better board and battery retention.
I'm also experimenting with porting of live video onto the tablet's screen; with a little, but some luck so far.
The tablet serves just as a node and the controller is capable of acting on it's own as a regular transmitter / receiver.
Similarly as with my previous project, this one consumes lot's of my time and resources - I'm getting close to the end of the line with the bidget too without my wife complaing ;) Therefore if You would like to contribute please feel free to contact me!
Comment by Radoslaw Kornicki on January 16, 2012 at 3:34pm
Comment by Squalish on January 16, 2012 at 4:52pm
Comment by joe on January 16, 2012 at 9:29pm Aside from the enclosure and sticks - this seems similar to another project mentioned at diydrones:
http://code.google.com/p/copter-gcs/
http://www.diydrones.com/profiles/blogs/coptergcs-now-supports-mavlink
Unfortunately, I don't think copter-gcs works over usb (?), just bluetooth - but it might be a start for someone that does not want to wait until this is released. I planned to try it on a tablet some time next month. Haven't thought about how to interface sticks though. PS3 controller...?
The pressure sensor reference in this project is an interesting idea
Comment by Roman on January 16, 2012 at 11:48pm Hello,
I used a custom IOIO board that take power from the tablet and not the opposite (but you can still power it with a battery).
If you look carefully at my blury video, you can see that this is not the IOIO that is driving the servos, the IOIO send a ppm signal to a hobbyking salvaged transmitter.
I had the same idea, to have the tab be a configurator and let the board be the brain, but I didn't implemented it yet.
Let me know if I can be of any help.
Comment by avionics on January 17, 2012 at 12:48am very very nice design.
Comment by Bart on January 17, 2012 at 4:54pm @joe
Connecting through USB was attempted (and almost entirely implemented) in a private branch of copter-gcs. However, the tested (unmodded) android phones/tablets didn't support USB/Serial comminication, so the options was let go to avoid major hassles with support.
@radoslaw Nice work! How did you get the MAVLink information parsed in android?
Comment by Pauli Seppinen on January 19, 2012 at 11:37am Nice work. I have had also similar ideas. My approach is a little bit more embedded. It is based on mbed controller, 4D touch screen, xbee and mavlink. Currently I have only the basic MAVLINK messages working with GCS and tested with modified UDB 4 in HIL sim with Xplane. Also in uplink the mode control is working in simulation. the downside of this approach is that it is not so suitable for online map, but x,y map is implemented. the good thing is that mbed API is fast development environment and adding features using mavlink API is relatively simple. I'll post something when the time is right
sweeeeeeeet!!!! I want one! I have a tablet and ardupilot...!!
Comment by Radoslaw Kornicki on January 19, 2012 at 7:20pm
Comment by Nick Mann on January 20, 2012 at 1:11pm Rad, your initiative is amazing. You could raise more funds the same way these guys did. You've clearly got a lot of intense interest and support.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1277 members
24 members
183 members
246 members
179 members
Powered by
