Futaba T14 Mz Mode configuration for all 6 modes
Here a quick guide how to set up your Futaba T14
I use 2 switches
  1st switch “SE” – 2 position switch
  2nd  switch “SB” 3 position switch
Switch “SE” – Master    Switch “SB” -  Slave
How it works:
 Switch “SE”    “UP”   position   switch “SB”  select modes 1,3,5
 Switch “SE”    “Down”   position   switch “SB” select modes 2,4,6
 Step 1 .To get the right min/max PWM output we first need to set the Endpoint of channel 5, in my case name of channel 5 is “ Aux 1”
Linkage menu > EndPoint (ATV) > ch5   Aux 1  Travel value 65% and 72% as showed photo
Step 2. Model menu >Prog. Mixes > select 1st mixing
Set Master “SW-E”  and Slave Aux 1  , Value “Offset by X and Y  +25%
To get "Logic " window:
Click second "On"  ( after green "on" )
v
What's all, enjoy..
Comment by Chris Anderson on January 25, 2012 at 2:41pm
Thanks, Alex. I've posted that in the manual here
Comment by Steven Thompson on January 27, 2012 at 12:50pm
Notice that my T14 had some different screens then Alex's so I updated the firmware.
Here are the instructions for anyone that is hunting for them.
http://www.futaba-rc.com/faq/faq-14mz-q864.html
I found the software updates easily enough off the main http://www.futaba-rc.com but the instructions were not directly linked from the same page.
Also, after the update, the radio no longer asks to be turned on or off at power up?
I will try and program the two switches with Alex's instructions next.
Comment by Eagle Wong on October 14, 2012 at 7:53am
i m using 18mz, i m following 14mz instruction. Unfortunately, the SE switch didnt function and SB switch work normally. Any experience on 18mz mode selection config?
Comment
