I've been working towards a realistic simulation of my high-altitude return-to-launch glider project in X-plane and this is the latest result which some here might find interesting.
The simulation is running with X-plane 9, APM-MP 1.1.36 (to keep the TAS into APM - more on that later) and a slightly modified version of ArduPlane 2.28.
To achieve the drop, I drag the aircraft up to the release altitude using the Local Map feature in X-plane and set the speed to zero. Whilst this isn't a perfect simulation of the intended release due to the flat orientation of the aircraft, for my purposes it is sufficient for now. Initially I allow the aircraft to accelerate in Manual mode until about 25kt IAS, then I switch to Stablize, manually manipulate the controls to pull out of the dive as rapidly as practicable before proceeding to switch into Automode. Eventually I need to code this whole process to trigger and execute all automatically in APM.
On this drop, I set the release point to be about 80 miles 'upwind' of the simulated launch point to make a rough allowance for the drift of the balloon on ascent. I am using the X-plane's real weather simulation (where it gets its weather data from some unknown on-line and quasi-real-time source), so I couldn't be absolutely sure what the headwind was going to be. This was the third in a series of flights, where the release point was selected from the experience of the earlier flights to give a likely head wind for the whole descent glide stage.
As you can see from the Google Earth image above, most of the travelling is done above the jetstream altitudes and the aircraft arrives at the loiter point still at nearly 45000 feet!
I logged the data using the data output to file feature in X-plane and then created a KML file using this method which uses this on-line file translator. Whilst logging the data in X-plane, I added more than just lat-long-alt and included some airspeed data so I could figure out a few other things.
The altitude profile shows the entire descent stage lasting a little over two hours:
and, the speed profile is here. You can see how the ground speed is fluctuating wildly as it tries to hold the loiter position. I'm not sure if the peak airspeed of nearly 500mph is achievable either because I didn't make a note of the Mach number, but it was probably less than 0.85. I suspect this could be an issue for airframe integrity...
More work needed here to limit the speed during the dive phase.
Finally, I integrated ground speed to give me an estimate of the distance I could feasibly travel from the release point. A pretty impressive number, don't you think? Line of sight all the way too! ;)
...and before I forget, here's a few details on the TAS problem I mentioned earlier.
The APM-MP-based HIL simulation up until recently has fed APM with true airspeed (TAS) from the X-plane data. I need this primarily for the PID loop speed scalar to allow stable control at high altitudes. The only problem is that this isn't what APM gets in real life from a pitot. The pitot-static system will give you indicated airspeed (IAS), or more correctly, dynamic pressure, which deviates wildly from true airspeed as density changes.
Michael Oborne has changed this in a later version (1.1.42 at least) so that APM now sees a realistic IAS number from X-plane, however this would mean I'd have to implement the IAS-TAS conversion in the APM code. I must do this at some stage, but for now having this little MP bug is a handy thing! :) Lazy? Moi...?
The APM software mod I've done is an embarrasingly simple one (yes, it's true I'm not a software geek!) where I expand the speed scalar clips from the standard 0.5-2.0 to a randomly selected 0.01-5.0.
Very interesting work. What airplane model did you use in xplane?
you could just assume the normal 2%/1000' conversion for IAS to TAS and you'd probably be close enough for hand granades.
-Beall
Comment by Jonathan Lussier on March 1, 2012 at 12:20pm I'll re-iterate with the others here, interesting work. I was planning on doing the same flight but with a Hobbyking Skyfun w/ APM2. Keep in mind, a dive to 500kts will be guaranteed to rip off your wings even with the low air density. Probably Same issue a 400 or 300 or probably even 200 kts. Due to the low density, your flight control surfaces will have almost zero 'effectiveness' and the aircraft will be tumbling out of control until the air density is high enough to make them effective again. Unfortunately this is also the speed at which air resistance will perform such ripping off of wings ;)
Thanks for your comments folks!
@Jonathan, I understand and share your concern about airframe damage, but I think you've possibly misunderstoon the possible mechanism. The X-plane simulation is a phenomenological model, that is to say the maths is modelling the effect of the air and gravity on the airframe during flight. In this sense, the X-plane model should behave similarly to the real airframe. The control surfaces are also similarly modelled and are indeed effective in the same way at the same indicated airspeed as at sea level, albeit the true airspeed is many times higher.
My concern with airframe integrity surrounds the possibility of flutter, which is an aeroelastic phenomenon where the interaction of aerodynamic forces on the airframe cause it to deform and change its lift coefficient in a positive feedback. In this respect, I'm most concerned about is vortex shedding triggering a resonant frequency in the airframe that becomes unstable or divergent. This would quickly overstress the airframe and cause it to break up - most probably starting with losing the control surfaces.
@Ryan, I'm not familiar with your 2% rule. Are you sure you're not confusing the ISA adiabatic lapse rate which is ~2°C/1000' ?
@Alex - the X-plane model is my own work that I've been doing to simulate and develop a glider specifically for this purpose. In this case it is the fourth generation of my HDwing concept - a forward swept quasi-flying wing with a wingspan of about 1.3m and a flying mass of around 900g
Monroe, I think I can improve it quite a lot by positioning the controls more favourably during the initial acceleration. I only need about 25kts indicated to fly stably, which at 120000 feet is 'only' a true airspeed of 350kts! (Mach 0.547)
BTW, I calculated the Mach number at the peak airspeed shown in the graph as 0.748. Possibly just transonic.
Comment by Paul Lamb on March 2, 2012 at 12:11pm Andrew, have you considered an air frame design similar to Scaled Composite's SpaceShipTwo. My understanding is the feathered wing provides stable flight characteristics at high altitude.
@Paul, I hadn't considered using any variable geometry airframe like SS2. My aim was to have a minimally complex airframe, hence the choice of flying wing with only two control surfaces. I hope to be flying at least 20000 feet higher than SS2 and my X-plane work suggests this is possible.
I have been doing some work in the last few days on improving the slow-flight capability and have made some interesting discoveries that have allowed me to operate in controlled flight to within a gnat's cock of the stall break. This has lowered my minimum controllable flight speed by about 3-4kts indicated and my airframe can operate in Stablise mode at just over 14kts IAS in low turbulence air.
This improved stability will need yet more code tweaking in APM to make it functional, but once I've got it running, I'll probably post some more about it, since I'm sure others will be interested in it, especially for auto-landing applications.
@Monroe, you're welcome to republish my work here with appropriate attribution. I'd suggest asking Chris Anderson as well, since he kindly runs this site for all our benefit.
Comment by Larry Grater on June 11, 2012 at 7:33pm Andrew, I have been having some issues getting X-Plane to give representative results at altitude for RC size aircraft. After reading a bit, the issue that I'm seeing is mentioned in the X-Plane (v9) documentation. Frame rate changes did help some. The plane is flying well at normal altitudes, but alt least for me, gains seem very ill conditioned at altitude. I found issues with the open loop dynamics at altitude that look as if Clp (roll damping) is scaled properly but Cldelta (roll moment/aileron) is not. The aero appears OK, including atmosphere, but pitch and roll are more sensitive than at low altitude. I have had success with the larger aircraft and found APM flew things like the F-102, B-52, others just fine with my RC gains. This was before special scaling. The simulation seems to start working well at 40k feet or so for my setup.
Can you provide detail on which X-Plane version, frame rate, and especially aircraft model? I am still using X-plane for SW verification of release, drogue release, timers, software robustness tests... but would like to be able to run end-end. The other option is flight gear. Thanks for the help.
Larry
Hi Guys! Sorry, I am away from civilisation for a while with a very poor internet connection apart from my Android device on which I can't figure out how to avoid the mobile version of this site, so I'm not able to comment much.
I don't think X-plane is useless Monroe. I have managed to do some good simulations, but it can lead you astray if you're not careful. The trick is understanding how it models the wing L/D characteristics and inputing data that is more realistic for our Re levels.
Also, I have bumped up the frame rate, or at least the calculation rate to improve the smoothness. It's important that the actual video simulation doesn't need to be that fast, but there is a parameter there that allows you to adjust the number of calculation iterations per frame refresh. That needs to be wound up a few notches. I can't tell you what I'm running at the moment, since I'm away from my simulation machine, but a figure of 5 or 10 iterations per screen refresh rings a bell.
Also, I am still running an older version of APM-MP - the one that accidentally confused TAS with IAS or was it the other way 'round? I use this when I am high-altitude flying, because MP doesn't access the temperature and baro that's required to do the calcs in the APM to correct for TAS.
I also have a TAS-based fiddle factor on the gain speed correction and have also widened the limits that APM uses for this factor - this was a huge step, as the default code limits it way too much to be useful at high altitudes. Take a look in my earlier blog posts and comments - I'm sure I've posted details of what I did somewhere.
I hope this helps some.
1286 members
679 members
51 members
39 members
Powered by
