How about this new Raspberry-pi Linux computer for $25 or $35 coupled with a sensor board ?
Has a header on board, video 256k memory hdi video or composit usc sdcard.......
see here for all specs..  http://wiki.xbmc.org/index.php?title=Raspberry_Pi
Earl
Comment by Ellison Chan on March 5, 2012 at 9:22pm
Suffers from perpetual out-of-stockitis, and it's got so many heavy connectors on it.
Comment by Earl on March 5, 2012 at 9:25pm
Mine is being shipped...
Earl
Comment by Earl on March 5, 2012 at 9:50pm
It only weighs 40g
Earl
Comment by Jan Detlefsen on March 5, 2012 at 10:21pm
has none of the ports that you need to interface with hardware and a lot of ports that are useless for this purpose.
Comment by Ellison Chan on March 5, 2012 at 10:39pm
It's the law of supply/demand.  The demand is always going to be higher than supply at the price that it's  being offered.  Their margins are too low to really keep any amount of stock to buffer the demand.  That's just the economics of it.  If they open source the design, then the Chinese clones can come out, then we're talking a different scenario.
It may be 40g, but could be lighter.  I bet most of the weight other than the PCB, is in the connectors, which are not needed, anyways.
Comment by Earl on March 5, 2012 at 11:27pm
its got i2c spi and others
Comment by CrashingDutchman on March 5, 2012 at 11:46pm
@Ellison, I think you are being to negative. They have 2 big distributors (Farnell and RS Components) which take care of enough stock. The initial plan was to have batches of 10K RPi's each, but the Raspberry Pi organisation has mentioned that supply will be on demand.
Furthermore, it's waaaay more powerful than any other $25/35 board currently available. If your plane can handle the extra weight, I see no problem. To interface with sensors, gps, etc... an Arduino can be used through the I/O pins.
Comment by Rien Matthijsse on March 6, 2012 at 1:42am
It eats your battery alive!
Comment by Andrew Radford on March 6, 2012 at 2:06am
Might make a decent field ground station
Comment by Helldesk on March 6, 2012 at 2:57am
I have one on order. It's the cheapest and most low-power way of getting a real PC up in the air, and the power draw shouldn't be more than a watt or two. This first batch was limited since it's a non-profit foundation, and the first production run was funded by the backers mortgaging their homes. From now on the new batches will follow demand, so give it some time and they'll be in stock for anybody wanting one to easily buy one. Removing unnecessary connectors should be easy and the GPIO pins on board can be used any way you want.
Comment
