ArduIMU+ V3 camera gimbal stabilizer on IndieGoGo
My original blog post offering a bounty on software for the ArduIMU v3 to make it into a very good standalone camera gimbal stabilizer attracted alot of criticism and at the same time alot more support.  There are many people who have joined my cause, and pledged to either match my bounty or contribute towards the bounty.  So many pledges that it has become hard to track.  One member suggested using Kickstarter. However as a non-US resident I was not able to create a project on Kickstarter so one has been created on IndieGoGo.
http://www.indiegogo.com/ArduIMU-Camera-Gimbal-Stabilizer?a=489994
Don't forget that whilst the $10 contribution is appreciated, and you contribute as much as you like, matching my $100 bounty is even more appreciated.  And for $225 I'll get a ArduIMU and solder the connectors and flash the firmware for you.
[EDIT: The 30 March deadline has now been extended until 11 May or until the bounty is claimed, which ever comes first.
It looks like this is getting pretty big with a number of contenders and backers, ie. more than just my $100 reward.  Whilst my offer for a $100 reward plus bonus still stands for the FIRST person to deliver code that meets the specification;  I would like to propose that the contributions/backers/funders on IndieGoGo vote at the end of the project (11 May) who should receive the funds raise on IndieGoGo (less the 9% fee that IndieGoGo charge).
So essentially there will be the $100 plus bonuses from me for the FIRST app, and the IndieGoGo pool for the BEST app.
Tags: arduimu, camera, gimbal, stabilization
Comments are closed for this blog post
Comment by Greg Fletcher on June 12, 2012 at 7:59pm
To any potential testers!!!!!!!!!!!!!!!   Check the wiki again. I had the pitch and poll pins revesed. Thanks to Torg's graphic it has been sorted out. Go by the wiki.
Comment by Torg on June 13, 2012 at 2:01am
something like that? I can't understand how you to connect - and + to servos, if someone clarify this I'll complete the draw for the wiki!
I hope that guys of arducopter not get angry for having used the same style.
PS
i'm going crazy with the two copy of the topic :(
Comment by Andreas Kielb on June 13, 2012 at 9:43am
In the meantime I also tried the code version from Michael Oborne and it worked out of the box for me. Though I got hyroglyphs in the terminal window the stabilization itself worked very well. From what I saw some of the code might be from here: https://code.google.com/p/gentlenav/source/browse/branches/MatrixPi...
Having a 2g accel calibration scale is very good for what I want but does anybody know the correct calibration registers for a gyro scale of 250 deg/sec. The ones used in the code are for 2000 deg/sec:
void MPU6000_set_gyro_calibration()
  byte regs[4];
  regs[0]=0x4C;
  regs[1]=0xCD;
  regs[2]=0x6C;
  MPU6000_set_mpu_memory(0x03, 0x7B, 0x03, regs);        //FCFG_1 inv_set_gyro_calibration
  regs[0]=0x36;
  regs[1]=0x56;
  regs[2]=0x76;
  MPU6000_set_mpu_memory(0x03, 0xAB, 0x03, regs);        //FCFG_3 inv_set_gyro_calibration
  regs[0]=0x02;
  regs[1]=0xCB;
  regs[2]=0x47;
  regs[3]=0xA2;
  MPU6000_set_mpu_memory(0x00, 0x68, 0x04, regs);        //D_0_104 inv_set_gyro_calibration
  regs[0]=0x00;
  regs[1]=0x05;
  regs[2]=0x8B;
  regs[3]=0xC1;
  MPU6000_set_mpu_memory(0x02, 0x18, 0x04, regs);        //D_0_24 inv_set_gyro_calibration
Simply trying to change  MPU6000_SPI_write(MPUREG_GYRO_CONFIG,BITS_FS_2000DPS);  to BITS_FS_250DPS compiles but leads to a trifting servo output...
Thanks,
Andreas
Comment by Greg Fletcher on June 13, 2012 at 8:54pm
@ Torq, Don't use those power connections. Thats the input to the onboard regulator, and you can't use that to power servos. Since you all ready need a 5 BEC you can use that to power the board. The power connections to the servos you need to do your self with perf board and a row of two or three pin connectors. Like this.
The input and output locations are correct. The capacitor is optional. Please test all your connections before powering up to ensure that no + to - pins are shorted or anything else. Please be careful so you don't fry your board. If you are not 100 % sure of what your doing, then don't do it ask for help.
Comment by Torg on June 14, 2012 at 3:45am
I'm sorry can't understand also because I don't have arduIMU yet...can you draw a scheme?
Comment by Greg Fletcher on June 14, 2012 at 8:25pm
OK Torg heres a picture. I guess I can make one. I was hoping you would do it for me. I all ready did the hard part after all :)
Comment by Greg Fletcher on June 30, 2012 at 11:04pm
To anyone testing this. After reading anther post about imu 3 v1.9 giving bad data, it hit me. I have a very early version of the board. In fact it didn't have a bootloader installed.
I have updated my gimbal controler to auto detect the hard ware version from the mpu6000 and set the accelerometer scaling. I got it from Arduplane 2.4 and ported it to the V1.9 gimbal controller.
Get the latest version here. I should have known of this problem, but both my board are version C the older ones. It will now switch to C or D automatically on start up.
Comment by Torg on July 17, 2012 at 11:52pm
Ok guys, some news about testing? did the yaw compensation work?
This is for the wiki
Comment by Denny Rowland on July 24, 2012 at 8:09am
Andreas
When changing to BITS_FS_250DPS was that a Drifting issue that you found?
Comment by Antonio Rodriguez Buendia on August 2, 2012 at 4:00am
Hi, I'm trying to use the v3 arduimu as 3-axis gimbal. I think I'm doing something wrong. use the latest version of arduino 1.0.1 use the code that is in http://code.google.com/p/gimbal-controler/ select duelinanove plate 328 and when I see the monitor will not let me send serial data to arduimu. Yesterday I got the version 22 of arduino send data but it only works the roll, and yaw are constantly pix -1. I need help urgently. sorry for my english
