ArduIMU+ V3 camera gimbal stabilizer on IndieGoGo
My original blog post offering a bounty on software for the ArduIMU v3 to make it into a very good standalone camera gimbal stabilizer attracted alot of criticism and at the same time alot more support.  There are many people who have joined my cause, and pledged to either match my bounty or contribute towards the bounty.  So many pledges that it has become hard to track.  One member suggested using Kickstarter. However as a non-US resident I was not able to create a project on Kickstarter so one has been created on IndieGoGo.
http://www.indiegogo.com/ArduIMU-Camera-Gimbal-Stabilizer?a=489994
Don't forget that whilst the $10 contribution is appreciated, and you contribute as much as you like, matching my $100 bounty is even more appreciated.  And for $225 I'll get a ArduIMU and solder the connectors and flash the firmware for you.
[EDIT: The 30 March deadline has now been extended until 11 May or until the bounty is claimed, which ever comes first.
It looks like this is getting pretty big with a number of contenders and backers, ie. more than just my $100 reward.  Whilst my offer for a $100 reward plus bonus still stands for the FIRST person to deliver code that meets the specification;  I would like to propose that the contributions/backers/funders on IndieGoGo vote at the end of the project (11 May) who should receive the funds raise on IndieGoGo (less the 9% fee that IndieGoGo charge).
So essentially there will be the $100 plus bonuses from me for the FIRST app, and the IndieGoGo pool for the BEST app.
Tags: arduimu, camera, gimbal, stabilization
Comments are closed for this blog post
Comment by Don LeRoi on May 20, 2012 at 7:34am
It is really hard to follow this discussion with 2 blogs on the same subject, with almost the same name, going on at the same time.
Is everyone aware that the dialog criss-crosses between "ArduIMU+ V3 camera gimbal stabilizer on IndieGoGo" and "Bounty offered a ArduIMU+ V3 camera gimbal stabilizer"?
Comment by Hai Tran on May 20, 2012 at 7:59am
So what's the verdict everyone?  I haven't had a chance to try it yet as Ive been flat out.  Looks like Michael is the only contender.
Contributors to the pot, are we happy to give the reward to Michael?  I'll give it 7 days, if no objections, I'm proposing to give the bounty to Michael.
Comment by Cliff Gill on May 20, 2012 at 10:45am
The code did verify (with the progmen modification, using arduino 022 relaxpatch, and  the duemilianove atmega 328 board) but I am getting errors in uploading the code to the board:
Binary sketch size: 27162 bytes (of a 30720 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0xfe
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Perhaps this is my bootloader issue with the ArduIMU as shipped?
Michael, is it necessary to have users copy the code from the other site and past it to your code, or could things be made easier for people to test it out?
Comment by Jani on May 20, 2012 at 1:36pm
Cliff,
Double check:
-Serialport number is correct
-You have selected right board from the list
-Press ArduIMU reset button just after clicking upload from pc. Timing is crucial here, not too soon or late, you need to experiment that.
Check first post here:
http://diydrones.com/forum/topics/documentation-on-v3?commentId=705...
I don't have ArduIMU, but i always had that same error with ArduinoPro mini board. Hitting board reset button before upload solved the problem.
Comment by Hai Tran on May 27, 2012 at 8:31am
Has anyone (besides the writers of the code) been able to confirm that there is a working ArduIMU Camera Gimbal stabiliser?  I personally have been busy and haven't had a chance to try yet.
@Marc that worked as in you were about to install it, or that worked as the gimbal stabiliser did a good job?
Comment by Cliff Gill on May 27, 2012 at 9:09am
I have attempted to test the gimbal stabilizer code, but have not yet had any luck in getting it installed and running. I have verified Michael's code in the IDE, and received a report of the code successfully uploading to the ArduIMU, (thanks to several of you offering good advice-Jani, Vernon, Micheal)  however it did not appear to run or affect any movement of the servos. I suspect that I have not really uploaded the code or some other issue other than the code is the problem. However, in order to determine this, I am going to have to go into much more detail with the arduIMU than I have in terms of uploading test code, etc which I have not had time to do yet. I am new to the arduIMU and have not used the one I received other than this attempted testing, so I don't really know if my hardware is healthy.
And Don, yes, the jumping back and forth between threads is a pain!
Comment by Michael Oborne on May 27, 2012 at 2:41pm
when you uploaded the code, it wil lgho though an init process, and print pwm's every seconds or so.
To enter the menu you need to press enter a few times.
Comment by Marc Puig Pasarrius on May 27, 2012 at 4:32pm
@Hai I managed to compile the code, now I've uploaded it to ArduIMU, but I suppose I've done something wrong because it doesn't work. I've connected two servos (PWM0 and PWM1) but they don't move. I get non ASCII messages through serial port and I can't enter CLI after sending some NL/CR.
Comment by Michael Oborne on May 27, 2012 at 4:41pm
this is what you should se eon the console
the servos should be connected to D8 and pwm0 for roll and pitch, also radio input on a0 and a1
Comment by Michael Oborne on May 27, 2012 at 4:44pm
i used arduino 022 btw
