One of the features of extreme high altitude flight is the high true airspeeds that are needed to generate the dynamic pressure required for airborne flight. To minimise these extreme speeds for my high altitude glider project, I wanted to increase the flyable operation envelope closer to the airframe's stall speed, helping the reign-in the stratospheric true airspeeds!
As I was playing about tuning the roll and pitch control PID loops using my airframe model in an X-plane HIL simulation, I discovered that a relatively large amount of derivative could yield some dramatic improvements to roll control when on the edge of the stall condition. The D term could be wound up at least an order of magnitude higher than could be tolerated at higher speeds.
To make use of this feature, I forensic'd my way through the codebase and the APM libraries to add a non-linearity to the PID speed scalar as it is applied to the derivative term. I did this by tweaking the PID.css file in the PID Arduino library folder (not the AP_PID, as it took me a while to discover..!) The mods are:
PID::get_pid(int32_t error, uint16_t dt, float scalar)
float output = 0;
float delta_time = (float)dt / 1000.0;
float deriv_scalar = (scalar - 0.5);// Compute proportional component
output += error * _kp;// Compute derivative component if time has elapsed
if ((fabs(_kd) > 0) && (dt > 0)) {
float derivative = (error - _last_error) / delta_time;// discrete low pass filter, cuts out the
// high frequency noise that can drive the controller crazy
float RC = 1/(2*M_PI*_fCut);
derivative = _last_derivative +
(delta_time / (RC + delta_time)) * (derivative - _last_derivative);// update state
_last_error = error;
_last_derivative = derivative;// add in derivative component
deriv_scalar *= deriv_scalar;
deriv_scalar = max(0,deriv_scalar);
output += _kd * derivative * deriv_scalar;
}// scale the P and D components
output *= scalar;
(Oh, and I corrected the spelling of scalar too!)
I have also expanded the clipping of the speed scalar delivered to the PID controller from the normal 0.5-2.0 in the standard APM codebase, to 0.01-5.0 I also chose to tune the controller with the reference speed to be the stall speed of the aircraft (7m/s) instead of the default cruise speed (25m/s).
The funny (scalar-0.5) term I have used to increase the decay of the term away from the stall speed without getting into complicated and CPU intensive maths. This allows a higher derivative gain to be used without unduly influencing normal flight.
So, having got this compiled and working in APM and X-plane, here are the results:
When I glide towards the stall speed in stabilise mode, holding as best I can, a level flight path, but with the roll control derivative term zeroed, which is more or less how I have tuned the controller till now, the airframe slows to approximately 16-17kts before a divergent roll instability develops. This instability can develop at slightly higher speeds too, but the main characteristic is once it develops, it is properly divergent. There is no saving it, except for a rapid pitch down and acceleration.
With the non-linear D term applied, I can now achieve relatively reliable roll control very close to the stall speed. The divergent instability is still there, but it is at a higher frequency and a much lower speed, clearing the way for operation much closer to the stall break than was possible before.
This work was done in X-plane 9, using an airframe model of my own forward-swept flying wing concept. The APM code was modified from Arduplane 2.28, using Michael Oborne's AP Mission Planner 1.1.42
You got it!
Comment by Gary Hunkin on March 19, 2012 at 12:21pm You're right Gary. Simulation is only a starting point, but sadly, getting it into the real world all takes time..
I plan on having pitot-static IAS measurement on my aircraft, although even that will be subject to some filtering delay. I like the idea of having an accelerometer integrator to estimate the real free-body velocity and being trimmed by more accurate, but slower data in the same way the Direction Cosine Orientation Matrix is 'corrected' (or should I say, errected?)
Could prove a hairy mammoth project in itself to get that working well though...
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
24 members
48 members
51 members
111 members
Powered by
