I have been building a variable pitch tricopter and wanted to share my results so far.
Basically - I chose a tri and not a quad, because the tri geometry is the same as a traditional heli 120 deg swash plate. Since I can't write a firmware on my own, I wanted to use an off the self solution.
I used a home made simple frame
3 e-flite park 370 hollow shaft motors with their variable pitch props
3 castle ESCs that I had laying around.
Here is a video of the tri on a table
http://www.youtube.com/watch?v=XI_8KCJyjcA
Here is a list of my various attempts
This allowed me to fly and hover, but very touchy
Check out the video above - and now I need suggestions .
I think one point is I need to redesign the pitch servo so that I use more of the servo throw, but mechanically reduce the movement - I have lost a lot of resolution using such a narrow pitch range in mission planner
suggestions welcome
Al
Sounds like my throttle governor code I'm working on is almost exactly what he needs for throttle control.
Comment by Ellison Chan on April 4, 2012 at 9:47am I messaged Al about adding the code to directly support this, but haven't had a response from him.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.130 members
686 members
51 members
24 members
185 members
Powered by
