Hi Everyone. Above is an intro video to the minimosd. It still needs a tiny bit of tailoring but I figured I would send it out to the community for review. A video series like this could be beneficial for our community to grow in the future. Open to adding on a distributor logo for some help supporting my own hobby/builds.
Of course the video is open to criticism and input. They are compiled from scratch in Adobe After Effects/Premiere.
Andrew
Comment by Mario bernard on April 16, 2012 at 12:47pm Sandro
I ' am also interested in the answers to Owen,s questions.
Thanks for your support.
@answering those questions:
1) In all the time since I started to develop it I never need to stablish a bootup sequence. However, I already have my XBee bricking because of receiving data from APM during the boot-up time;
2) 4.9v at APM input end, and 11.3v at Vid_IN is quite fine.The 12V is related to your camera and Video TX. Even 6V is enough to get video overlay working. Example --> 6V Video TX + self powered GoPro.
3) The reset pulse from your PC is just 200ms. So, everything above it is more than enough.
4) An OSD layout is saved on EEPROM. After a firmware upgrade it should not corrupt.
5) After the update processes the FTDI will do an auto-reset.
No problem on dedicate some time answering any question from you guys. Just sometime I'm kinda busy and will do it with certain delay. ;)
Thanks Sandro, that's awesome, appreciate it. Seems I've exhausted all possibilities then. Either I'm slightly retarded (it's been known), or there is a hardware issue. I'll keep nagging the 3DR team until I get a response for support.
cheers for your time!
Comment by Mario bernard on April 24, 2012 at 4:13pm Hi all,
i just received my 2nd miniosd and ws able to compare and do some troubleshooting of my 1st miniosd.
Everything works fine withthe new Miniosd. Firmware , charset and screen layout all workfine.
This time i only feed the miniosd via the apm using the two stages jumpers unlike with my 1st miniosd.
The board is much cooler then feeding the 2nd stage via 12v. I think that the board probably fried from too much heat.
The first board is probably dead, I am able to connect to it, upload firmware, but unable to load charsets. I am not getting any videoout either, I tried feeding it with both methods, via apm only (with soldered jumpers) and with 12v (without jumpers), but same results. The charset file is not corrupted eitheras suggested, because i use the same file for the second board and it works fine. So, i think that this board is fried. Since i am using the same connectors,camera, batteries, ftdi cable, etc, i was able to rule out those components as being the cause. My conclusion, i think that using 12v fried that board because i got darn hot. So it cost me 2 boards to lurn that ! My suggestion .......feed the osd via the Apm. Only my 2 cents....
@Mario bernard, when did you order your first MinimOSD?
Comment by Mario bernard on April 25, 2012 at 9:22am Gent
Ordered on march 20th, an received 2 to 3 weeks later
Comment by Mario bernard on April 25, 2012 at 11:04am Avec des commentaires comme ca sur un forum, ca sent le taxi...
Comment by Patrice Mainville on April 25, 2012 at 11:06am LOL
Comment by Mario bernard on April 25, 2012 at 11:11am i hope you guys understand that this Patrice guy is a friend of mine....perhaps, sometimes stupid, but, hey! so am i....
LOL. We act out sometimes. Anyway, on your first MinimOSD, you connected it to both power sources (5v from APM and 12v from Tx/ Vid Cam) and the board burned? On the second board, it is just powered with from the APM's 5v? Correct me if I'm wrong. I'm asking because I also have the MinimOSD but I have not set it up, even just power it up.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.106 members
1279 members
671 members
183 members
182 members
Powered by
