OK, to explain, i finally got the autopilot sorted and installed in a test plane and all went according to plan, until the wing support failed on my manual flying back to land. what takes away the pain is that it wasn't in my full size plane, that I maidened last weekend successfully with 2 x 8 minute flights.
This was my first successful attempt at getting the APM to first stabilize and then circle RTL, it was on the 4th and now final flight that we were trying to fly to some way-points that I caused the plane to crash. lucky though the plane came down in the carpark (between the bmw and landcruiser) and the APM module seems to be intact, so bining a $60 plane was worth it.
Next stage is to get the next test plane happening before transferring to "richies UAV" ( i might have to give it a model name- maybe MARK I).
"Richies UAV" - Mark 1 in test flight mode. OK the cardboard on top looks rough, but it flew, next step is to make some covers and mount a camera.
Flight Control Box, FITPC2 - 12 Volt micro computer - running Win7Pro, with Samsung 19inch (model S19A450BW) runing on 12 Volt Dc 24AH Gel Cell, the computer uses 9 watts and the monitor about 19 Watts and is quite clear in daylight, and was the hardest thing to find that didn't use alot of power, I also looked at some 12inch screens from China but they did not have the screen definition to use as a computer monitor.
Richie
Love the story and the photos of your new setup! A big improvement over your first plane (and not just because it's in one piece)
Comment by Tom in ON on March 24, 2012 at 7:11pm Richard, could you post the successful PID configuration for your Cessna? I have the same one (CESSNA 206T) and I should be ready for flight within a month or so.
Thank you.
Tom
Comment by Richard Unwin on March 24, 2012 at 7:28pm Tom, so far i have just been using the base PID config that comes with it.
richie
Comment by Tom in ON on March 24, 2012 at 7:32pm Thank you, Richard for the reply. So that' good news, it may work right out of the box for me too! :)
Great setup for the field monitor. I am planning to build a sun shield around my 19" laptop and take that out to the field.
Comment by Dez Socks on March 25, 2012 at 11:52am between the bmw and landcruiser
Close one.Phew!
Comment by Dez Socks on March 25, 2012 at 6:03pm Just to add i recently broke the nose of my wilga 2000.The nose was fairly weak to begin with.I used a 2 liter bottle two repair it,fits perfect.Just cut the top off one.Looks better than the original,tougher and disposable.
Reason i say is because the mounts,servos and material of the nose looks the very same as mine.
Comment by Richard Unwin on March 26, 2012 at 2:03am
Comment by Simon Amstel on March 26, 2012 at 2:26am IF that's the same foam Cessna I had (marketed in the UK by Century) it was a *pig* to fly. I'm impressed any Autopilot could keep it in the air, I certainly struggled!
Comment by Simon on March 26, 2012 at 10:48am Hey, you have a great setup there!
I have a bad crash myself some time ago. The impact speed was 140 km/h and the battery hit the APM. Although APM still works (after bending the pins back where they belong) I am a bit scared that it might got damaged.
Would you guys use an APM after a hard crash again?
Cheers,
-S
Comment by Tom in ON on March 26, 2012 at 5:09pm @ Simon: I do not have the experience yet of crashing one, but if you do a thorough check of all parameters and readings per the setup guide, I do not see why not it wouldn't work as a new one. After all it's all a bunch of 101010100.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.115 members
183 members
1280 members
87 members
673 members
Powered by
