There are a lot of home-brew parts in this machine (no fooling, really).
I had orignially fabricated parts based on the 'A' frame but after noticing the 'B' release, I ordered replacement parts and modified mine as close as possible. The bottom plate is 1/8 aircraft plywood painted. The top was made from an FRG piece I had in a junk box.
Getting access to the PDB is now much easier and if you have an 'A' and break it, go to the 'B'.
The legs are made on my home-brew CNC Dremel router.
Using the posted 3DR drawings, I made some G-code that cloned the 3DR leg pretty close. I didn't bother with the nice radius at the 'foot' end but may tinker with the code later. The harvested circuit board material found new life rather than being tossed in the landfill to decay over a thousand years. This way I get to break it in spectacular fashion!
I used 6-32 screws and remachined some aluminum hex standoffs I had for the leg hardware. I let the CNC router crank out two complete sets of legs as I suspect a few will get broken while I earn my quad wings.
Using what I have in my shop/garage and buying significant parts from 3DR has been my approach.
Things left to do/make are:
More to come!
April 14, 2012
I've been assembling the PBD, ESC and motor connectors.
I went with the XT60 for the battery side rather than the Deans.
After routing the motor wiring as mentioned previously, I added another layer of heat shrink to the wiring to provide another level of anti-chaffing.
For those of you interested in the actual hole pattern on the arm...
As this is my trainer quad, as mentioned before, I think the next arm will have radiused corners out past the motor. This will reduce impact edges and give the arm a more finished look I think.
Here is one of the arms with the extra heat shrink at the motor, the ESC with all connectors zip-tied in place.
I took the Arducopter, prior to mounting the just shown wiring updates, to one of the local shops in Greenville, SC, The Great Escape. Keith is the resident heli-nut and we discussed the need for me to spend time with a simulator. Real Flight 6 Heli now has a quadrotor in the selection. The in-store demo unit had me hovering and breaking props in between reset button presses. It looks like a great product and at rev 6, it seems that it won't be going away anytime soon.
Keith inquired about the PDB and had not heard of 3DR. A quick trip on one of the store's PCs to the DIYDrones Store and he was in love with the Hex copter. I tried to explain the APM and its open source development. He was accustomed to a single threaded application (dumb controllers) rather than a 'smart' controller like APM.
We had a good visit for about an hour or so and I promised to return when the Arducopter was getting closer to flying.
Before I get the funds for the APM order, I may build a servo 'stimulator' and check the motor directions. Anyone ever try that before bolting in an APM?
May 19, 2012
Checklist items acquired for the quad:
Still building funds for the APM2 purchase. I gathered parts for the servo stimulator and need to get that sub project going. I may just breadboard it and then used one of my favorite programming languages - solder.
Comment by Jonathan M on April 1, 2012 at 2:15pm Very nice! Curious how those legs will withstand hard landings with all of those little stress concentrators (holes).
Is your CNC a completely DIY solution or do you have plans for it? I really want a cheap CNC machine for little parts like these. By G code is that a CAM type software used to program the CNC?
The legs are probably tougher than plain FRG. There are layers of copper foil, 5 layers I think, and the holes are full of solder. In between the foil layers is FRG. We will see how they hold up. The price was right.
My CNC is based on the (now out of business) Kleinbauer Brute. Unless you have access to some good shop tools, I would not recommend that device and already I could use a larger unit. I made this one with the intent to learn from it and use it to prototype circuit boards.
The controller is the other half of the unit. I used LiniStepper boards for the motors and built the entire thing into a rack mount style cabinet. I can use the controller on another router if I sell off the Brute.
The CNC hobby is a real time sink. The machine, the controller, and the software all have learning curves.
Regarding G-code, it is the programming steps/language that are used to drive the router motors. I use TurboCNC software. It is DOS based and free. There are several ways to back into/stumble into the CNC hobby. Plans and kits are abundant now. Several good books also exist to give a newcomer an idea of what they would be getting into.
In short, you have to ask yourself what is more important? Sole sourcing an entire project or enjoying flying the project? I am a maker at heart and had enough resources to build what I have. Each person's resources will differ.
Comment by Agustin Monteverdi on April 1, 2012 at 5:45pm would you mind telling what wires did you use for the esc extension to the motor(the ones that go inside the arm)?
The wires are the silicone type that were provided (already installed on the motors) with the motors from 3D Robotics.
The arms were fabricated to allow a shorter wire length.
Rather than entering the arm from the outermost end (current 3DR frame), they enter from the arm top.
The motor mount holes are not centerline with the arm but angled.
This was required to allow the wires exiting the motors to align with the center of the arm.
I hope your question was answered. Thank you for looking at my project!
pretty impressive way to mount motor. This way you can expect less deformation on the arm compared to having them on the center line. Cross section of my arms motor ends (from 3DR) are not square any more :-(
Also keeps the wires away from the sharp edge of the arm. I had mine sheared off when the copter crashed into a wall sideways
Ruwan - Thank you. I had to make an alignment jig for the arm end that allowed me to mark the motor holes on the arm ends. It is a work in progress that will allow me to fabricate arms faster.
Andy - My thought exactly. The 3DR arm, an improvement over the initial Arducopter arms, still looked to allow the situation you described. Of course with practice, none of will crash our Quads... eventually.
The next set of arms I make will have radiused ends, rounded to the diameter of the motor housing, to reduce the chance of corner injuries though the diameter of the props are more a danger than corners. At the very least it will remove unneeded metal and look cooler.
Comment by Ellison Chan on April 14, 2012 at 7:27pm RD, nice build. Simple but effective.
Should put some rubber grommets where the motor wires are coming through.
Comment by Steven Hickerson on April 14, 2012 at 9:21pm I was wondering what material is used for the arms in this? It looks like a low gauge aluminum square tubing?
Sorry if this is common knowledge, I've been dreaming about building my own quadracopter for some time now, but the price tag on the kits always scares me off. I don't really want to spend 600 dollars on a kit, just looking to piece it together myself and I have access to some light weight aluminum if that is what is being used here and would work.
I've got plenty of arduino boards laying around that I could use for controllers along with some XBee transmitters to work out some sort of RC. Would only have to worry about sourcing the motors, rotors, and battery then... of course those are the expensive parts but I don't think those would cost me 600 dollars hehe.
Comment by Ellison Chan on April 14, 2012 at 9:33pm Steven, have a look at my blog:
http://diydrones.com/profiles/blogs/first-flight-of-3d-printed-fire...
If you want to DIY, you can use TREX 450 tail booms. They are strong, straight, and light.
The arms and frame should cost about $70.
There are also wooden frame alternatives from Hobbyking:
http://www.hobbyking.com/hobbyking/store/__502__501__Multi_Rotors_P...
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
671 members
1280 members
8 members
182 members
Powered by
