There are a lot of home-brew parts in this machine (no fooling, really).
I had orignially fabricated parts based on the 'A' frame but after noticing the 'B' release, I ordered replacement parts and modified mine as close as possible. The bottom plate is 1/8 aircraft plywood painted. The top was made from an FRG piece I had in a junk box.
Getting access to the PDB is now much easier and if you have an 'A' and break it, go to the 'B'.
The legs are made on my home-brew CNC Dremel router.
Using the posted 3DR drawings, I made some G-code that cloned the 3DR leg pretty close. I didn't bother with the nice radius at the 'foot' end but may tinker with the code later. The harvested circuit board material found new life rather than being tossed in the landfill to decay over a thousand years. This way I get to break it in spectacular fashion!
I used 6-32 screws and remachined some aluminum hex standoffs I had for the leg hardware. I let the CNC router crank out two complete sets of legs as I suspect a few will get broken while I earn my quad wings.
Using what I have in my shop/garage and buying significant parts from 3DR has been my approach.
Things left to do/make are:
More to come!
April 14, 2012
I've been assembling the PBD, ESC and motor connectors.
I went with the XT60 for the battery side rather than the Deans.
After routing the motor wiring as mentioned previously, I added another layer of heat shrink to the wiring to provide another level of anti-chaffing.
For those of you interested in the actual hole pattern on the arm...
As this is my trainer quad, as mentioned before, I think the next arm will have radiused corners out past the motor. This will reduce impact edges and give the arm a more finished look I think.
Here is one of the arms with the extra heat shrink at the motor, the ESC with all connectors zip-tied in place.
I took the Arducopter, prior to mounting the just shown wiring updates, to one of the local shops in Greenville, SC, The Great Escape. Keith is the resident heli-nut and we discussed the need for me to spend time with a simulator. Real Flight 6 Heli now has a quadrotor in the selection. The in-store demo unit had me hovering and breaking props in between reset button presses. It looks like a great product and at rev 6, it seems that it won't be going away anytime soon.
Keith inquired about the PDB and had not heard of 3DR. A quick trip on one of the store's PCs to the DIYDrones Store and he was in love with the Hex copter. I tried to explain the APM and its open source development. He was accustomed to a single threaded application (dumb controllers) rather than a 'smart' controller like APM.
We had a good visit for about an hour or so and I promised to return when the Arducopter was getting closer to flying.
Before I get the funds for the APM order, I may build a servo 'stimulator' and check the motor directions. Anyone ever try that before bolting in an APM?
May 19, 2012
Checklist items acquired for the quad:
Still building funds for the APM2 purchase. I gathered parts for the servo stimulator and need to get that sub project going. I may just breadboard it and then used one of my favorite programming languages - solder.
Steven, the arms are only dimensional 0.75 square aluminum from a DIY/home improvement store. This stuff is usually found in the hardware section but.. be forewarned that it isn't cheap either. I thinka 4 foot length of the stuff is around $16. If you use the version 'A' drawings located HERE you will see how much of the stuff you need.
The arm tubing is from some antenna projects gathering dust. It was still purchased from the same kind of store. Having a small mill and lathe in my tool collection made the machine work moderately easy. I did mess up on the frame mounting holes and had to adjust the frame plates to work with the machined arms. This stuff all takes lots of time to learn to use and get running.
I looked at many alternatives to building the quad and found that this site, and the folk that support it, were the best resource. The posting of the drawings was the clincher for me. My approach has been to use what was in the shop/garage and buy/source the same stuff you mention - motors, ESC, 'brains' etc.
I ordered a set of 'B' frame plates so that I could get the dimensions right on the next quad. The home-brew CNC router can make a leg in less than 10 min. While in that mode, two complete sets of legs were fabricated.
Ellison, Thank you. The next build may have a longer cable slot, possibly a plastic insert to prevent chaffing. The hole was made with a 4 flute 0.5" mill cutter. I filed the top edge a bit to take the corner off. As this is my first quad, and probably subject to much bashing around, it will be a work in progress.
Comment by Steven Hickerson on April 15, 2012 at 9:13am Thanks RD. Yeah seeing other designs helps me but this is really something I'm planning to build and design myself from the ground up. That is part of the fun of it for me :) I'll take ideas from other designs like the material used and such, but I plan to create my own "brains" wiring, etc. I will even write all the coding to control it from scratch :) The only things I will source are the parts that are impractical to build myself such as the motors. I even have my own 3d printer (only prints up to 7" x 7" x 6" though) that I'll use to make small custom parts that I need :) I think I've got a 10 foot stick of 1" aluminum square tubing, that may be to big though if .75" was used here. I also think I can get it cheaper than $16 dollars for 4 foot of it from a local metal shop that my Dad does a lot of business with (he has a steel fabrication shop so orders a lot of metal).
Thanks again for replying, and for the link to their designs! :)
Comment by Marc on April 15, 2012 at 5:14pm good project,
i built a hex exactly the same ali square arms using 2mm carbon plates for the middle have a look at my photo gallery.
regards
Comment by Luiz Miranda on April 15, 2012 at 6:33pm Very nice, specially the easy access to the PDB, good job
Comment
51 members
51 members
185 members
691 members
Powered by
