APM Mission Planner now has a proper installation utility!
One of the priorities of the APM team is to continue to find new ways to make it easier to use. The Mission Planner is a big part of that, with it's one-click firmware loading, but author Michael Oborne has now done it again with a great installation utility (64-bit Windows here, 32-bit here) that not only installs the Mission Planner, but also detects which APM you have and installs the right driver for it. That's like five manual steps eliminated!
Great work, Michael!
(As always, it will also check for updates at startup and download the latest version)
Comment by Crispin on April 8, 2012 at 3:07pm
Managed to do a screen print before it vanished..
Direct-x is the culprit
Comment by Eagle on April 8, 2012 at 3:34pm
Crispin, I found the file : Microsoft.DirectX.DirectInput.dll in C:\Program Files (x86)\APM Planner
...maybe try to uninstall and re-do the installation again... (if you have not tried that already) reminds me an old joke.  One day 3 engineers were on the highway and oops the car just stopped...  The mechanical engineer open the hood and verify the engine without any luck.  The electrical engineer verify the battery connections without any luck also.  The software engineer  suggestion was to get out of the car and get back in again...
Hope you will be able to sort this out. good luck.
Comment by Crispin on April 8, 2012 at 3:38pm
Nope, file not there and re-install does not help. :(
Comment by Michael Oborne on April 8, 2012 at 4:31pm
actualy. this link
http://www.microsoft.com/download/en/details.aspx?id=8109
DirectX End-User Runtimes (June 2010)
Comment by Michael Oborne on April 8, 2012 at 5:42pm
im also uploading some new msi's right now, that will fix it.
Comment by Taylor Collins on April 10, 2012 at 5:49am
The Mission Planner installer worked great for me.... and the USB interface is finding the Arducopter board, etc. on my brand new Windows 7 laptop, but I have run into a brick wall as far as going any further.  Is there someone that I could pay for twenty minutes of assistance (by phone, Skype, e-mail, whatever...).  If I could get my computer actually communicating with the Ardu board, I think I would be off an running....
Thanks!
-Taylor
Comment by Crispin on April 10, 2012 at 6:03am
If it is APM2, you need to upload (without pressing the connect button) new firmware first. After that, choose the port and 115200 speed and you should be good.
If it is APM1, make sure you have the port and speed correct.
Comment by Taylor Collins on April 10, 2012 at 6:10am
Thanks... It's an APM1... the speed is definitely at 115,500 (I'm not at the right computer at the moment, so that number may not be exact.)  The documentation says that the Port number is shown in Mission Planner, but I'm darned if I can see where that is.  The Windows Device Manager clearly shows the Arduino board connected at Port 3 .....
-Taylor
Comment by Crispin on April 10, 2012 at 6:21am
in Mission planner, you need to select the port (3), choose ArduCopter, speed (115200) and click connect. You should see a lot of "stuff" screaming past in the other MP window.
Not much else to it AFAIK
Comment by Taylor Collins on April 10, 2012 at 6:22am
While I'm asking Noobie questions....  I discovered the reference to the switch position under the "?" help tab.
I assume that this small, white switch should be towards the RC headers pins while I am trying to upload the Quadcopter firmware ?  In the "Firmware" window, there is a drop down to select TCP or UDP?  Which one ?
In the Terminal window, it asks for a remote host ip (by default, it seems to come up at 127.0.0.1)  I assume this is the address where Mission Planner looks for the latest firmware ?  It also asks for "enter remote port"... What is correct for this?
Thanks for the help!
-Taylor
Comment
