[UPDATE: This project is now being ported to a proper Google Code repository and manual. For instructions, start there. You can also join the ArduRover User Group here.]
Hello to ALL, the new firmware for APMRover v2 has been tested successfully on my rover on may 1st, 2012 on full autonomous reco mission following a navigation plan. This new release of the APMRover v2 works on the APM v1.4 with the OilPan shield (magnetometer + MT3329 GPS) and also of course on the APM v2. The previous version of the APMRover v1.0 was a light size version specially designed for the APM1280 CPU (only) board and the MT3329 GPS.
For the frame, I have used a Traxxas Monster Jam Grinder with a brushed and high power motor Titan 12T and its XL-5 ESC.
The APMrover UGV is able to run itself following a list of recorded waypoints. The waypoints list (FPL) can be preloaded with the APM Mission Planner OR better in live, recorded by the pilot himself (with the SW7) during a manual run and then replayed in a full autonomous mission.
The firmware APMrover2 for APM v1 + OilPan or APM v2 successfully tested can be downloaded HERE
The APMrover v2 is also online on the official ArduPilot-Mega GIT repository HERE
Below the PID setup for the APMrover v1 and v2:
The light firmware APMrover1 for APM v1 (CPU 1280 or 2560) that I have tested can be downloaded HERE
Here's how to connect your cables:
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Have Fun and Enjoy with the APMrover...
Regards, Jean-Louis
Comment by Chapelat Daniel on May 13, 2012 at 10:03am Bonsoir Jean Louis
I download APMrover21_alpha_firmware because tomorrow I will befree for testing, I just can not configure channel 5 and 7 with APMplanner1.1.85?
Did you change anything at this level or is it due to the updating of APM planner
Thank you and congratulations
Daniel cordially
Hello Daniel,
I haven't changed anything about the channel 5 and 7 in the APMrover 2.1.2 alpha
Regards, Jean-Louis
Comment by Franco Borasio on May 13, 2012 at 10:57am Hi Jean-Louis
I've tryed the new version and now is all OK!!!! the problem was due to something in 2.0b revision, because I've compass with components "down" and now I've change from arduino and everything is allright.
Is very strange that in revision 2.0b it was ok without any change !!!!!
The sonar is ok it too, I've change the range from arduino at 200 cm, otherwise the car can not turn in time, and I've make an offset of the sonar about 25° in the sky. It will be very confortable if we can change the sonar distance directly from mission planner.
Another thing is to control the "start accelleration" parameters, because when it start or stop, the movement is very hard...... there is some parameter I can change? if I drive it in manual mode I can make very soft accellerations with throttle stick.
Compliments for your efforts.!!!!
best regards
Franco
Comment by Chapelat Daniel on May 13, 2012 at 11:38am Bonsoir Jean Louis
A Force To have bugs with windows I'll become a pro .. sic ..!
I think the update APM planner was not appreciated by microsoft;
I will thank you tomorrow morning plunges
thank you
Daniel
Hello Franco,
Glad to see that you have succeed in the test of the APMrover 2.1.2.
I have added a new param which can be updated with the APM mission planner:
ROV_SONAR_TRIG set by default at 200 cm according to your test
latest update: APMrover 2.1.2a (alpha) at:
http://ardupilotdev.googlecode.com/files/APMrover21_alpha_firmware.zip
Regards, Jean-Louis
@Daniel: Good luck in you soon tests of the APMrover 2.1.2
Jean-Louis
APMrover v2.1.3 release:
I have added a new feature: it is now possible to reset the home position without restarting the APM with the option switch SW7.
in MANUAL mode, if you put the roll stick to full right and then switch the SW7 to ON then OFF, this clear the list of the stored WP and also store the current location as the home position for the RTL.
The APMrover v2.1.3 firmware can be downloaded at:
http://ardupilotdev.googlecode.com/files/APMrover21_firwmare.zip
and pushed my GIT repository at:
Regards, Jean-Louis
Comment by Franco Borasio on May 14, 2012 at 7:03am Hello Jean-Louis
I've now try the 2.1.3 firmware...... everything is OK !!!!!
for the instructions to reset home position, please write "HOLDING ROLL STICK TO FULL RIGHT" because may be people can find mistake, because they just turn to the right the stick and if they let it, it turn back to the center...
VERY GOOD!!!
JL, I noticed you're doing much work in your clone, but only updating the version in trunk occasionally. I was hoping to make a few changes as requested by Michael Oborne in order to develop our own environment for MP.
How is the best way to do this?
Comment by Franco Borasio on May 14, 2012 at 7:31am Jean-Louis, I'm thinking about a particular situation I found with sonar car.
If car is turning to the left for ritch a waypoint and in the same time it found an obstacle in front of it, it doesn't turn left or right, the car goes straight because of the sonar compensation. So the best way to jump this situation and other similar to this one, would be: IF SONAR DISTANCE IS LESS THAN ?cm (this must be a variable easy to change) THEN STOP, TURN THE WHEELS TO THE RIGHT, GO BACKWARDS UNTIL SONAR READ ?cm (this must be another variable easy to change) THEN GO ON WITH MISSION. It's obviously that if after this maneuver sonar read again a distance less than the first variable, the car repeat the maneuvre until it find a street without obstacles.
It would be a maneuver like if you have to go out from a parking (more or less) !!!!!
WHAT DO YOU THINK ABOUT IT? may be a good idea, just for now, in a second time you can implement it!!!! or we can thinking to put a servo under sonar, turn it left and right make a triangulation beetween the magnetometer and the sonar side at the moment it see an obstacle .................etc etc (like Robert said)
Best regards
Franco
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.87 members
1280 members
7 members
179 members
16 members
Powered by
