APMRover 2, a fun UGV project for full autonomous recon missions...
[UPDATE: This project is now being ported to a proper Google Code repository and manual. For instructions, start there. You can also join the ArduRover User Group here.]
Hello to ALL, the new firmware for APMRover v2 has been tested successfully on my rover on may 1st, 2012 on full autonomous reco mission following a navigation plan. This new release of the APMRover v2 works on the APM v1.4 with the OilPan shield (magnetometer + MT3329 GPS) and also of course on the APM v2. The previous version of the APMRover v1.0 was a light size version specially designed for the APM1280 CPU (only) board and the MT3329 GPS.
For the frame, I have used a Traxxas Monster Jam Grinder with a brushed and high power motor Titan 12T and its XL-5 ESC.
The APMrover UGV is able to run itself following a list of recorded waypoints. The waypoints list (FPL) can be preloaded with the APM Mission Planner OR better in live, recorded by the pilot himself (with the SW7) during a manual run and then replayed in a full autonomous mission.
The firmware APMrover2 for APM v1 + OilPan or APM v2 successfully tested can be downloaded HERE
The APMrover v2 is also online on the official ArduPilot-Mega GIT repository HERE
Below the PID setup for the APMrover v1 and v2:
The light firmware APMrover1 for APM v1 (CPU 1280 or 2560) that I have tested can be downloaded HERE
Here's how to connect your cables:
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Have Fun and Enjoy with the APMrover...
Regards, Jean-Louis
Tags: ARDUPILOT, AUTOPILOT, DRONE, UAS, UAV, UGV
Comment by R_Lefebvre on May 14, 2012 at 7:46am
I think a great setup for a Rover would be to have the sonar, and a camera (if you use one) on a mast elevated some distance above the rover.  This will prevent the sonar from getting a false return from the ground.  It also provides a better viewpoint for the camera.  This idea seems to be fairly common for a system like this.
Comment by Jean-Louis Naudin on May 14, 2012 at 8:19am
Hello Franco,
Good news to see that every thing is OK for you. Of course, I agree with you, we must wrote:
"HOLDING THE ROLL STICK TO FULL RIGHT" then switch the SW7 to ON then OFF to clear the stored wp list and storing the current location as the home position for the RTL.
Good remark and enjoy yourself with the v2.1.3.
Regards, Jean-Louis
Comment by Franco Borasio on May 14, 2012 at 8:38am
Hello Robert,
Yes this would be a good system, but as you can see into the second picture you've posted, the best one is to have a stereovision with a special softwer that can recognize the obstacle and control the right deviations to avoid it.
I don't know if arduino can do it alone, or if we need an external PLC to do it.
We've made something like this for special applications, but it was very expensive!!!! May be now there is something cheaper like pixel software relevation that can do it, or something like kinetic that in the second revision can even recognize the sores of the mouth!!!!!
For now I've found that with the right sonar offset, the software go on without big problems, also becouse if you put a stand over the rover, you have to pay attentions at the obstacles over you (like tree branches!!!!)
Best regards
Franco
Comment by Chapelat Daniel on May 14, 2012 at 8:39am
Jean Louis goodnight
  I spent several hours looking for my configuration ptoblèmes Radio:it turns out that the connection: (Rec ch8: channel mode switch 3positions) makes me crash the apm (without ch8 Rec is connectedgood) with APMrover2dual_firmware, orAPMrover21_alpha_firmware APMrover21_firwmare.
I leave all the connections (rover) and I tried to configure the radiowith APM Planner ArduPlane-2.34 .. and there I have no problemeverything is ok, I guess a "bug" in APMrover21_firwmare, but my skills do not allow me to find, I use a futaba radio 7cp in 35Mhz
  have you any idea?
thank you cordially
Daniel
Comment by Jean-Louis Naudin on May 14, 2012 at 8:52am
 The APMrover v2.1.3 firmware is now on the official GIT repository at:
Revision:86bccc3730ac
Regards, Jean-Louis
Comment by Jean-Louis Naudin on May 14, 2012 at 8:54am
Hello Daniel,
I am using the APM mission planner v1.1.77 without problem with the APMrover v2.1.3.
What is the version of the mission planner that you are using ? Does it is in 32 or 64 bits ?
Regards, Jean-Louis
Comment by Chapelat Daniel on May 14, 2012 at 9:01am
hello jean louis
I use 32-bit APM v 1.1.85
cordially daniel
Comment by Franco Borasio on May 14, 2012 at 9:02am
Hello Jean-Louis,
what do you think about the software sonar upgrade I've post to you?
Regards
Franco
P.S. I use the last one revision of APM planner without problems!!!!
Comment by Jean-Louis Naudin on May 14, 2012 at 9:24am
Hello Franco, this seems an interesting update, but today I don't have a sonar sensor on my APM so I am not able to do testing and deep dev about this...
Regards, Jean-Louis
Comment by R_Lefebvre on May 14, 2012 at 9:49am
JL, I was trying to make the changes that Michael requested for MP, and did a test compile, and it failed.  So I reverted back to what is in trunk to try again, and again it failed.  I can't get it to compile. Do you know what could be wrong?  I get a ton of errors about MAVlink.
Comment
