[UPDATE: This project is now being ported to a proper Google Code repository and manual. For instructions, start there. You can also join the ArduRover User Group here.]
Hello to ALL, the new firmware for APMRover v2 has been tested successfully on my rover on may 1st, 2012 on full autonomous reco mission following a navigation plan. This new release of the APMRover v2 works on the APM v1.4 with the OilPan shield (magnetometer + MT3329 GPS) and also of course on the APM v2. The previous version of the APMRover v1.0 was a light size version specially designed for the APM1280 CPU (only) board and the MT3329 GPS.
For the frame, I have used a Traxxas Monster Jam Grinder with a brushed and high power motor Titan 12T and its XL-5 ESC.
The APMrover UGV is able to run itself following a list of recorded waypoints. The waypoints list (FPL) can be preloaded with the APM Mission Planner OR better in live, recorded by the pilot himself (with the SW7) during a manual run and then replayed in a full autonomous mission.
The firmware APMrover2 for APM v1 + OilPan or APM v2 successfully tested can be downloaded HERE
The APMrover v2 is also online on the official ArduPilot-Mega GIT repository HERE
Below the PID setup for the APMrover v1 and v2:
The light firmware APMrover1 for APM v1 (CPU 1280 or 2560) that I have tested can be downloaded HERE
Here's how to connect your cables:
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Have Fun and Enjoy with the APMrover...
Regards, Jean-Louis
Comment by Franco Borasio on May 14, 2012 at 12:56pm Hello Jean-Louis,
OK!!! I stay tuned !!!!!!
Regards
Franco
@Robert: Ok, for the update about the "learning" mode instead of "stabilize" mode. Until the MP is updated, we keep as the stable version for the APMrover the v2.1.3 and the v 2.1.4 in a "under dev" state.
FYI: Today, there is no improvement or no new features between these two version. The only differences are located in the compatibility with the mavlink library and the "learning" mode Vs the "stabilize" mode. So, for the tests fields we use the APMrover v2.1.3 until the APM mission planner will be updated by Michael.
Regards, Jean-Louis
Comment by Chapelat Daniel on May 15, 2012 at 12:35am Hello Jean Louis
My problems are solved with radio "PMrover214_new_mavlink" Iallowed myself to hereby amended: APM_Config_Rover.h this wayfor the Xbee communication:
// Serial port speeds.
#define SERIAL0_BAUD 115200
#define SERIAL3_BAUD 57600
Good test for my part I will do tests on my return Friday
Regards Daniel
Hello Daniel,
Glad to see that you have solved your Xbee communication problem and that the test of the APMrover is now OK for you.
Good recovery and see you on Friday,
Regards, Jean-Louis
Comment by Franco Borasio on May 15, 2012 at 1:46am Hello Jean.Louis,
can we have a parameter for control the start and stop acceleration of the rover?
until now when I start with auto mode, the car has very hard start and stop. If we can control the acceleration parameter, it will be amazing!!!
Best regards
Franco
Hello Franco,
This can simply done by reducing the Energy/Alt PID gain, it is currently set at: 0.1
may be you may try 0.05 or 0.02 (in Arduplane PID window)
or in the Parameters list: ENRGY2THR_P (proportional) you may also trying to tune ENRGY2THR_I (Integral) and ENRGY2THR_D (Derivative)
Happy tuning, Jean-Louis
Comment by Franco Borasio on May 15, 2012 at 3:47am Hello Jean.Louis
I've try with suggested regulations, I've also try with Integral and Derivative term (positive and negative), but changing all of them, I've a normal velocity reduction and not a soft start and soft brake. It's obviously that reducing the velocity the start and stop are a little bit slow. What I mean is to have a constant good velocity, and in the same time control the start and stop motor function. Is like we need a logaritmic throttle curve reponse instead of linear throttle curve for control only the accelleration and brake function.
Regards
Franco
Hello Franco,
May be you may try to use the parameter THR_SLEWRATE this allows to damp the increase/decrease of the throttle in % change per second maximum. This is only used in AUTO mode. If it is set to 0 (by default) the throttle_slewrate is disabled.
Regards, Jean-Louis
Comment by Franco Borasio on May 15, 2012 at 7:21am Hello Jean-Louis,
THR_SLEWRATE make a strange effect. If you set it to -10, the rover begin to go forwards for 3 meters, after stop very soft (and this is good) and start do go backwards by it self with a very soft acceleration (the acceleration is perfect but not the direction). After that if you set it to +10, the car start to go backwards, after 3 meters stop very soft, and start very soft to go frontwards.
After this if you don't change it, and put rover in manual and after in auto, it start hard like usually.
I think all these pid doesn't control right the car, may be are good for a plain but with rover they do some strange effects!!!!
I think is better to do it with the program or with a dedicated pid parameter.
What do you think?
regards
Franco
Comment by MVeloso on May 15, 2012 at 8:15am
Jean-Louis thank you very much for work
This is my rover with:
- Mega motor(aircraft)
- Aircraft esc.
- No rear movement
- APM1 (2560)
On field the test was ok. Some lack of precision(2-3 m) but it was a narrow road.
I need to reduce the velocity of the vehicle.
I will post a video.
I am wondering to add some solar cells.
Have fun….
MV
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
83 members
24 members
682 members
1288 members
Powered by
