APMRover 2, a fun UGV project for full autonomous recon missions...
[UPDATE: This project is now being ported to a proper Google Code repository and manual. For instructions, start there. You can also join the ArduRover User Group here.]
Hello to ALL, the new firmware for APMRover v2 has been tested successfully on my rover on may 1st, 2012 on full autonomous reco mission following a navigation plan. This new release of the APMRover v2 works on the APM v1.4 with the OilPan shield (magnetometer + MT3329 GPS) and also of course on the APM v2. The previous version of the APMRover v1.0 was a light size version specially designed for the APM1280 CPU (only) board and the MT3329 GPS.
For the frame, I have used a Traxxas Monster Jam Grinder with a brushed and high power motor Titan 12T and its XL-5 ESC.
The APMrover UGV is able to run itself following a list of recorded waypoints. The waypoints list (FPL) can be preloaded with the APM Mission Planner OR better in live, recorded by the pilot himself (with the SW7) during a manual run and then replayed in a full autonomous mission.
The firmware APMrover2 for APM v1 + OilPan or APM v2 successfully tested can be downloaded HERE
The APMrover v2 is also online on the official ArduPilot-Mega GIT repository HERE
Below the PID setup for the APMrover v1 and v2:
The light firmware APMrover1 for APM v1 (CPU 1280 or 2560) that I have tested can be downloaded HERE
Here's how to connect your cables:
More infos at: http://diydrones.com/profile/JeanLouisNaudin
Have Fun and Enjoy with the APMrover...
Regards, Jean-Louis
Tags: ARDUPILOT, AUTOPILOT, DRONE, UAS, UAV, UGV
Comment by Cody O. on June 18, 2012 at 5:59pm
Chris: I'm using a joystick instead of a radio.  I tried reversing the joystick input, but it appears to only effect the APM2 output when it's in MANUAL mode and not AUTO mode.
Comment by Cody O. on June 18, 2012 at 7:41pm
EDIT: It looks like Jean-Louis already addressed this:
"Comment by Jean-Louis Naudin on April 29, 2012 at 10:24pm
To reverse the direction of the wheels in MANUAL and STABILIZE mode you must reverse the direction on your transmitter.
To reverse the direction of the wheels in AUTO mode you must use the APM mission planner and reverse the direction of the ROLL (see below)."
So, reversing the joystick input is the same as reversing the transmitter, and affects MANUAL and STABILIZE modes.  Reversing ROLL under "Radio Calibration" affects AUTO mode, even though I'm not using a control radio.  I'll have to give this a try!
Comment by Aizzat on June 19, 2012 at 12:23am
Hi Jean,
I compiled your code, but get bunch of errors. My sketches folder is correct. Any advise ? See the snapshot error below: Your help is much appreciated. Thanks!
Comment by Aizzat on June 19, 2012 at 12:35am
All,
I managed to fix the errors. Specific compiler associated with firmware version will do as mentioned by Jean in previous comments. I missed that. So sorry. Thanks!
Comment by Aizzat on June 19, 2012 at 2:16am
Hi Jean,
This may be a beginner question. But I would like to know if my receiver is only three channels. What is the correct configuration for output from APM 2.0 as I scare I would connect it wrongly.
Can I connect like this at APM2.0 Output:
ch1:Wheel Servo
ch2:not use
ch3:ESC
ch4: not use
Thanks!
Hello Anish,
If you have only a 3 channels receiver, you may use:
ch1 = roll (to wheel servo)
ch2 =  pitch (to ESC for throttle)
ch3 = to APM ch8 (for mode change)
for those have 4 channels, the ch4 can be connected the APM ch7 (for options trigger)
Regards, Jean-Louis
Comment by Evaristo Ramos, Jr. on June 19, 2012 at 5:18pm
Hi all,
Would this transmitter be good enough to use with this setup as I have ordered everything else except for the wireless controller pieces and a UBEC (which i am still trying to understand what it does)
http://tinyurl.com/cbpr96k
Humbly,
Roo
Admin
Comment by Thomas J Coyle III on June 19, 2012 at 7:31pm
Evaristo,
UBEC stands for Universal Battery Eliminator Circuit. Most ESCs have a BEC built-in and can supply +5 vdc to the AMP1. Some people use a separate battery and a BEC to supply the APM1. It would be best if you checked the wiki or elsewhere in this thread to see what is the best way to power the APM1.
TCIII
Comment by Adam Scriven on June 19, 2012 at 7:41pm
Just an FYI, the newbie's guide is still pointing to the original ArduRover wiki page and not to this discussion. If this is the 'official' ardurover stuff, shouldn't the wiki or the newbie guide link be changed?
Comment by jesse on June 20, 2012 at 3:51pm
I get this error when I compile.  I have no clue what to do.  Anyone care to help.  Thanks.
GCS_MAVLink\GCS_MAVLink.cpp.o: In function `mavlink_check_target(unsigned char, unsigned char)':
C:\Users\JJ\Downloads\arduino-1.0.1-windows\arduino-1.0.1\libraries\GCS_MAVLink/GCS_MAVLink.cpp:20: multiple definition of `mavlink_check_target(unsigned char, unsigned char)'
APMrover2.cpp.o:C:\Users\JJ\AppData\Local\Temp\build8732094509770592562.tmp/APMrover2.cpp:3937: first defined here
c:/users/jj/downloads/arduino-1.0.1-windows/arduino-1.0.1/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
GCS_MAVLink\GCS_MAVLink.cpp.o:(.data.mavlink_system+0x0): multiple definition of `mavlink_system'
APMrover2.cpp.o:(.data.mavlink_system+0x0): first defined here
C:\Users\JJ\Downloads\arduino-1.0.1-windows\arduino-1.0.1\libraries\GCS_MAVLink/GCS_MAVLink.cpp:20: multiple definition of `mavlink_comm_0_port'
APMrover2.cpp.o:(.bss.mavlink_comm_0_port+0x0): first defined here
C:\Users\JJ\Downloads\arduino-1.0.1-windows\arduino-1.0.1\libraries\GCS_MAVLink/GCS_MAVLink.cpp:20: multiple definition of `mavlink_comm_1_port'
APMrover2.cpp.o:(.bss.mavlink_comm_1_port+0x0): first defined here
APMrover2.cpp.o: In function `test_imu(unsigned char, Menu::arg const*)':
APMrover2.cpp:(.text._ZL8test_imuhPKN4Menu3argE+0x28): warning: internal error: out of range error
APMrover2.cpp:(.text._ZL8test_imuhPKN4Menu3argE+0x2a): warning: internal error: out of range error
APMrover2.cpp.o: In function `test_mag(unsigned char, Menu::arg const*)':
APMrover2.cpp:(.text._ZL8test_maghPKN4Menu3argE+0xa8): warning: internal error: out of range error
APMrover2.cpp:(.text._ZL8test_maghPKN4Menu3argE+0xaa): warning: internal error: out of range error
FastSerial\FastSerial.cpp.o:(.rodata._ZTV10FastSerial+0x6): warning: internal error: out of range error
AP_GPS\AP_GPS_Auto.cpp.o: In function `AP_GPS_Auto::init(GPS::GPS_Engine_Setting)':
C:\Users\JJ\Downloads\arduino-1.0.1-windows\arduino-1.0.1\libraries\AP_GPS/AP_GPS_Auto.cpp:40: warning: internal error: out of range error
Admin
Comment by Thomas J Coyle III on June 20, 2012 at 3:58pm
jesse,
First of all, what version of ArduRover2 are you trying to compile? To the best of my knowledge, if you follow JLN's instructions, you should be using IDE 1.0 relaxed to compile ArduRover2 2.20a. You must use the relaxed versions of the Arduino IDEs. I believe that ArduRover2 2.13e/2.16 should be compiled with IDE 0022 relaxed. Also, you should be using the libraries that accompany each version of  the ArduRover2 code. I have had no problem compiling and uploading the three different versions using the relaxed versions of the Arduino IDEs. Hope this helps.
TCIII
Comment
