Various modes of Marcy 2's fully functioning wifi camera are shown. A 168Mhz 128k RAM chip compresses JPEG & streams on 802.11g. As the frame size increases & color is enabled, the framerate goes down. Body movement around the antenna makes it drop packets. It still compresses a lot faster on 168Mhz & 128k RAM than a 166Mhz Cyrix with 64MB SDRAM did, 15 years ago. The Cyrix only did 5fps 320x240 color, if you were lucky.
With a new, unmelted camera finally arriving, the true frame rates & bit rates could be known.
640x480 color: 3fps 800 kbit
640x480 grey: 4fps 1 megabit
320x240 color: 20fps 2.5 megabit
320x240 grey: 30fps 3 megabit
Quite an improvement over the UART cams from Sparkfun. The bitrate got a lot higher when the lens wasn't melted. All the 640x480 modes had to go to single buffers to fit in the RAM. They could double buffer if the quality was reduced way down. Noise is now the real problem. Capacitance directly on the wireless dongle is the key. Networking bitrate is way up. Bluetooth wouldn't be an option.
Desoldering position for the melted cam.
Another $20 in Nate's retirement fund.
Another perfect soldering job.
Marcy 2's eye.
It would be revealing to know how bad the AR drone cameras are, but the guys who use those don't know what a rolling shutter is.
Marcy 2 now needs a huge cash infusion to continue. Hobbyking has stopped restocking most everything that made it not Tower Hobbies, leaving only full priced versions.
The very 1st images received from Marcy 2's wifi camera.
Great Work Jack,
what're your starting point code for this development ? A lot of time ago i develop a video compressor based on SH1 . I used H.264 compressor algorithm and i had only 4 fps as your cyrix 166 :)
Are your development opensource ? Can we share our work ? The MP32F4 use your same micro controller STM32F4 . What wifi module are you used and how you connect it to micro ? I'm very interest to your work.
Best
Roberto
Comment by Thomas Saunders on May 4, 2012 at 2:15am Hi Jack,
I'd also be interested in seeing how you ran the camera through DMA. I've been playing with an OV7076 module and the STM32F4, but reading in the image data can be quite slow, so I'd like to use the DCMI.
Comment by Bruno Amui on May 4, 2012 at 4:56am The complexity and quality of your work is really amazing. It would be a really great progress to the whole community to have access to the source code, as well as to the schematic of the board.
Great work Jack! Ingenious use of the mane as a test subject as well! :D (damn, I miss my hair...)
Jack, you should setup a Donations process... I am sure a lot of people would jump in and send some $ to you to make you push the limits again.
I sure would send something, your work is always brilliant and ahead of the main stream.
100 person sending you $20 would make a difference...
Comment by Jack Crossfire on May 4, 2012 at 1:24pm Donations may not work with the way unemployment compensation works. Kickstarter reports all earnings to the IRS & at least until the benefits run out in 5 months, that could cost a lot more in the end.
Well, make a wishlist then with the hardware you could use. Maybe a DIY-fairy brings something to your door..
Comment by Greg Fletcher on May 4, 2012 at 8:21pm That's just amazing Jack. Your work in the video field is really paying off. One thing confuses me or makes me dizzy, what is this cams purpose on a monocopter? is it ground based orientation/nav?
Comment by henk de bakker on May 14, 2013 at 9:06am Hello Jack,
The WiFi solution is realy intresting, could you post some more info on this ?
i think it's a RTL8188 USB chip ?
thanks
Comment by Tommy Larsen on May 14, 2013 at 9:52am I would say that making a solution for any composite camera would be much more interesting. Like the "Axis M7001". I'm looking for something similar to the Axis these days, because the Axis is very expensive. Ane suggestion btw ?
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
186 members
1298 members
24 members
51 members
Powered by
