After putting the copter together over a few exciting evenings, initial test flights showed some very strange control responses with pitch and roll being swapped. I could "correct" this by swapping my Aileron and Elevator receiver channels, but that made the autopilot's stabilization input completely unpredictable. I checked my wiring and documentation, and found the following:
The PDB that comes with the 3DR-B is oriented to use rotor 2 and 3 as the quad's front in x-mode. See page 7 of this doc:
http://stuff.storediydrones.com/ArduCopter3DRAssemblyInstructions
The APM2, however, thinks that rotors 1 and 3 are in the front:
http://code.google.com/p/arducopter/wiki/APM2RC
So, wiring the PDB correctly and hooking it up to the APM2 results in a copter that has its motors turned 90 degrees from its board. The solution is simple enough.
Maybe this is a well-known issue... It was news to me. Or maybe I've missed something obvious in the the build process. If your newly-built quad is behaving oddly, look into it.
I think you may be reading the PDB lettering a bit too literally. All those sources show the same motor order, it's just the PDB is offset by a few degrees with placed in the quad in X mode.
I did notice this on my quad build but realized that the PDB has no influence on the orientation except as a mechical reference to the builder. It is important, of course, to make sure the correct ESC wire is going to the correct motor via the PDB. That could be confusing as you point out.
As a reality check for those not flying yet (meaning me too), use a meter to confirm the continuity from the APM ESC output to the appropriate ESC.
Comment by Nathan Martz on May 13, 2012 at 12:51pm The fact that the X-mode forward arrow is nearer to motor plugs 2 and 3 doesn't mean that those are the front two motors, it's just showing the direction the board should face. When you go to plug in your motors, you should still plug them into the motor positions referenced in the page 10 diagram, 1 and 3.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
24 members
51 members
1288 members
78 members
Powered by
