I bought a PhoneDrone board a couple of months ago, hoping to use the board in order to build some sort of autopilot or plane stabilization in conjunction with any standard Android phone that supports Android 2.3.5+.
My idea is to use the sensors in the phone to stabilize a plane. Initially I thought about stabilizing even a multirotor, but I soon figured out, that would be way to complicated. So I´m starting with a plane. In my case I´m using the EPP-FPV from hobbyking since it has plenty of space to hold all the electronics and flies very docile.
After getting in contact with the nice folks at the 3drobotics support I was able to get some code samples and build a basic prototype connecting all the pieces. A Samsung Galaxy Nexus, the PhoneDrone board, a Turnigy9x receiver and some servos which you can see in the embedded video at the top.
The next step is involving the onboard gyro and accelerometer to stabilize one axis of the plane. The code is allready in the repository and I tested it very briefly but I wanted to see first how an APM2.0 stabilizes my plane. Also I´m thinking very hard about backup solutions in case my PhoneDrone-Android setups fails in the air. I´ve studied the failsafe of the APM1 and APM2 and decided to get a
"Wireless Buddy Box System" with
4 or
8 channels from Hobbyking. Dedicated hardware failsafe seems like a good idea to me.
Next steps are actually getting experience with the APM2.0 to get a real feeling what to expect from a plane autopilot since I´ve only used this kind of hardware on multirotors so far. Then I will see how much of the functionality I can cover with the "IMU" that is in my phone. It´s really cool if you think about it, my Galxy Nexus Phone has all the sensors of the APM2.0 (gyro, ass, compass, gps, baro) plus a "modem" and a very handy input device called a touch screen to configure the software :) Plus it has tons of memory, dual core ARM processors and it´s own backup battery.
I´ll keep you guys up to date with my progress here on diydrones. You can also look directly at my github for changes in the code, my youtube channel or twitter.
I´ve also created a google group to exchange ideas and experiences with other people who bought a PhoneDrone board.
Comment by Samuel on May 13, 2012 at 7:32am Looks like your servo code is not quite right. The servos move much smoother with the rc control than with your phone. Looks like there is a timing issue, had that with my DIY headtracker too. Do you use ~50hz as frequency for PWM calculations? I had more than 50hz in the beginning and the servos moved like in the video where you move them with your phone.
But good job so far. If you need help with ppm/pwm calculations you can contact me, then i might help you a bit.
Excellent! I added a link to this on the product page.
Comment by deadfalkon on May 13, 2012 at 8:00am
Comment by Douglas D. on May 13, 2012 at 8:45am The shaky servo behavior is dew to the skin/friction on the screen. Garbing and pulling the skin...to fix this i suggest the "anti fingerprint/smug and anti glare screen protector. Should solve your problem for a couple bux on e blaaaaah. Same concept on your laptop mouse pad. Smooth ones become sticky, but the ruff surface ones tend to be much smoother motion and reaction.
Comment by Ellison Chan on May 13, 2012 at 9:32am Falko, you know, having worked with IOS and Android, that these are not realtime capable OSes. Given this, it would not be safe to rely on the android phone as your IMU. I would recommend using a separate I2C based IMU like a pololu 9dof imu as your main sensor for craft stabilization. It would be safer to have the stabilization code running on the arduino. You could use the Android as a secondary source of flight control, like the joystick interface that MP supports, which injects control packets to the APM.
Comment by deadfalkon on May 13, 2012 at 10:37am
Comment by Ellison Chan on May 13, 2012 at 11:31am Falko, current the Arducopter code updates IMU readings, and flight control at 100hz. This is controlled by a hardware timer, with no scheduler. That means tasks are very close to real time. Having realtime task execution doesn't really depend on how powerful the processor is. As long as you can guarantee that a task is always executed at 100hz, within an acceptable delay, then you're fine. The problem with Android is that without a preemtive scheduler, and realtime kernel, you cannot guarantee the 100hz task scheduling. You can for instance be blocked on I/O without a realtime kernel and miss running the the stabilizaton task for several time slices. That's ok, for non-realtime tasks, since the scheduler will usually compensate by letting the task run longer the next time it schedules in and at the end the task is still getting the same amount of cpu time. However for realtime tasks, missing several time slices, will leave your craft out of control for that amount of time, and there's no making it up later by updating the IMU multiple times, or updating your crafts attitude more often.
This what I think for Arducopter. But, this situation may be different for planes. In the case of planes, a stable platform will fly fine, without the need for constant stabilization, so realtime updates are not so critical. In that case, perhaps an android based IMU may work. On the other hand, one can also argue that a plane is usually flying faster that a multirotor does, and any loss of control is a cruise missile with no guidance system.
To me, a safe flying platform, plane or multirotor, should not rely on an android based phone.
Comment by deadfalkon on May 13, 2012 at 1:20pm Ellison "cruise missile with no guidance system" is a little over the top don´t you think ;-) We´re talking about a foam plane and with the "Wireless Buddy Box System" as an external switch that can take away the power from the autopilot at any time. Maybe I´ll have to see if use the phone only as an IMU and all the processing that needs to be realtime will happen in the ATmega2560.
This will stay an experiment, and I will make sure it is safe at all time. To adress your last sentence: To me also, a safe flying platform should not rely on an phone or even an autopilot, that´s where I come in as a human pilot :)
Comment by Ellison Chan on May 13, 2012 at 2:18pm Well, my concern ii with using the phone as the sole IMU. The fact is that a multirotor is impossible to "fly" without some kind of automatic stabilization. I think it may be beyond even and fighter pilot's capability. Without an IMU there's very little that the 2560 can do, other than control the speed of your motors. Again, in the case of an airplane, a stable platform should fly fine without stabilization, so a buddy system would be a good backup, providing that you tell the phone is not working, and was able take control in time. Not trying to discourage any experimentation, just adding a voice of caution.
Comment by johnm545 on May 14, 2012 at 11:53am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.130 members
118 members
4 members
682 members
51 members
Powered by
