Firmware and Windows Client are made from a modified version of the orginal one found here : arducam-osd
Update 30 January 2013, new version include :
To enable this feature and display selectable parameter screen (screen 1) :
After you'll we see a check screen (screen 2) where you have to :
Then you can select parameter (screen 3) to tune with CH6, those parameters are :
After tuning a paramter, go back to screen 3, and save new parameter value with yaw stick to the left.
Compiled firmware : 20130129_ArduCAM_OSD_.rssi.time.status.climb.current.tuning.mavlink...
Firmware sources : Arducam_osd_src.zip
Update 16 August 2012, new version include :
Compiled firmware : ArduCAM_OSD_.rssi.time.status.mavlink1.0.hex
Windows client sources : OSD_IDE.zip
Update 23 May 2012, new version include :
"Charset update" was removed hardcoded, so to upload a new charset, you'll have to use the orginal firmware to do it and after you can use this firmware.
This new version need a new charset (MinimOSD_20.mcm) and the new client
Firmware : ArduCAM_OSD.rssi.amp.status.hex
Client : OSD_Config_RSSI_Status_Amp.exe
Charset : MinimOSD_20.mcm
Comment by Chris Kreuzer on June 17, 2012 at 2:02pm Your firmware doesnt work.. :-(
Comment by Nguyen Ha Minh on June 18, 2012 at 4:23am @Chris Kreuzer : you mean it doesnt work with Mavlink 1.0 and AP 2.6 right?
Comment by Chris Kreuzer on June 18, 2012 at 5:04am Yes
Comment by airmamaf on June 18, 2012 at 8:10am Add this parameter #define MAVLINK10 DISABLED in APM_Config.h to make firmware working with MAVLink 0.9
Comment by airmamaf on June 18, 2012 at 11:25am I got a problem with Arducopter 2.6, it's impossible de read any value from analog pin A9 to A4 (issue 417), so RSSI display is always 0 for me. Anybody has the same problem here ?
Comment by Bjarni on June 27, 2012 at 3:47pm I just wanted to check if you have made a mavlink 1.0 version of your minimosd firmware... I was using your firmware before and that solved the problem having to restart the minimosd at every startup of the APM.. but now when the newest firmware of the APM is using mavlink 1.0 your minim osd firmware does not work...
Comment by airmamaf on June 28, 2012 at 10:06am No mavlink 1.0 version done and planed yet. If you want to use my custom firmware with arducopter 2.6, you can disable Mavlink 1.0 and then it will ouput mavlink 0.9 messages
Comment by Bjarni on June 28, 2012 at 2:39pm OK... thanks for the information :) I will try that
Comment by Gábor Zoltán on July 16, 2012 at 8:51am Hi
How can i connect my receiver?
Is there a picture? :)
Comment by Fête Mobile on July 16, 2012 at 4:47pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.679 members
1286 members
51 members
39 members
24 members
Powered by
