I'm thinking seriously about getting a CNC.  Been browsing on Ebay.  Mostly these China made 3020 cnc machines are popping up, and they all seem to  be relatively well priced.  Just thought I'd get some opinions from members on any actual experience on these.  Also any recommendations on getting a hobby CNC machine in general would be greatly appreciated.  I'm planning on using the machine to make hub plates, motor mounts, etc.  I'd probably be milling aluminium and/or carbon fibre.
LIST OF EQUIPMENT UNDER CONSIDERATION:
Motors/Controllers:
  1. cadcamcadcam.com (servo motors and controller)
  2. 3-axis Stepper Motor System based on DQ542MA, on Ebay
  3. 6-axis Stepper Motor System based on DQ542MA, on Ebay
  4. DC1 Servo Motor Controller, from Makerbot
  5. Servo Motor Encoder
05/26/2012:  After some discussion.  This blog is starting to look into building a CNC machine of our own.  Keep following to stay informed.  We're in the brainstorming stage at this point any input from users is welcomed.
05/27/2012: DIYDrones CNC Project group is created.  Let's move our activity to that group.
Comments are closed for this blog post
Comment by Ellison Chan on May 24, 2012 at 5:11pm
Dany, from what I gathered, the 3040 models are practically same stepper motors, with the same precision.  The difference is that the 3040's all seem to have higher powered spindle (800w in the one your linked)  The one Iinked above the 3020 has only a 180w spindle.
Comment by S.G. Sutter on May 24, 2012 at 8:07pm
Has anyone built the FLA-100 from Fine Line Automation?
https://www.finelineautomation.com/store/s/CNC%20Router%20Kits/FLA1...
Seems to have a good size working area, and can handle aluminum if you go easy on it.  I'm looking at putting one of these together sometime this summer.
Comment by Ellison Chan on May 24, 2012 at 8:21pm
That FLA-100 looks like it has a pretty large x-y-z travel, but it looks like the spindle gantry is using only one rod, which from what I learned today, is not going to be very solid.  At least the 3020, I linked above has two rods holding the spindle on the gantry.
Comment by Philipp Witte on May 24, 2012 at 10:25pm
I would recommend these cnc machines...
http://steering-inc.com/
They are hand-made in the USA. I have a very similar one that I use to cut foam cores and it works great!
Comment by Bjørn Didriksen on May 24, 2012 at 10:57pm
have a look at www.diylilcnc.org.
I have bought one, but not assambled it yet...
The price to have this delivered in Norway was a pain in the ... ;-)
Comment by John Arne Birkeland on May 25, 2012 at 3:27am
Just a little shout out to anyone cutting CF. CF dust is nasty stuff, and VERY dangerous to get into the lungs. Make sure you have a good suction/ventilation system and that the dust is blown outside.
Comment by R_Lefebvre on May 25, 2012 at 6:11am
John, what is the deal with CF dust?  I've cut a bit using a dremel tool.
Comment by Ellison Chan on May 25, 2012 at 6:42am
I guess you can get black lung, like coal miners got, if exposed on a long term basis.  One tip I saw on this done by some on this forum, was to do the milling in a water bath.  Then there's no air borne carbon dust, and way less mess.
Also, Bjorn, the kit you linked to seems to be just some CNC'd wooden frame parts.  None of the hardware or electronics seems to be included, and it's already $225.  Am I right in that?
Comment by R_Lefebvre on May 25, 2012 at 6:54am
Yes, that's sort of what I figure.  I see this warning all the time from hobby people, but I've never seen anything official such as an MSDS sheet stating the fact that it's carcinogenic or anything like that.  Best I can figure, as long as you aren't doing it on an industrial scale, day-in day-out, it's not going to be a problem.
I've done a fair bit of heavy fabrication in my shop, built a large HD offroad camping trailer, and that project meant a LOT of grinding with angle grinders which generates tons of black dust from the grinding wheels.  I'm sure that's not good for me either but it was only over a few months timeframe, I don't fabricate for a living.
I can't imagine carbon fiber is worse than that?  It's not asbestos.
Comment by Ellison Chan on May 25, 2012 at 7:04am
Here's a product sheet from one manufacturer warning of Pneumoconiosis.  Better safe than sorry, you want to enjoy yourself with life long healthy flying.  I wonder if this kind of thing applies to printer toner, which is polymer based, I think.  I have had a lot of exposure to that from re-filling the toner cartridges.
