I built the AC SIm to do gain tuning and now AB testing of various control algorithms. I've made some significant strides in the control loops, so I though I would detail out how it was done.
There is very little code left over from AC 1 in the current code base. When I started AC 2, I used the v1 control loops and assumed they were good. (Everyone was very happy at the time with them.) I also had no real way to measure the performance of them.
A few months ago I started to get very suspicious that the old carryover code was causing a lot of the flight headaches I've been experiencing such as aggressive flight leading to a flip. Or slow, wobbly response in descents. Max was complaining that AC2 lacked "wings". That's not a lot to go on, but it is real feedback that something needed done.
I built the SIM specifically to tackle this type of problem and here is how it was used:
In the SIM a parameter was created called g.test. A checkbox toggles the value of this param and the boolean value is used to turn on or off chunks of code. This gives me a side-by-side comparison of the impact.
Suspect code:
Attitude.pde: get_stabilize_roll() and get_stabilize_pitch();
// limit the error we're feeding to the PID
target_angle = constrain(target_angle, -2500, 2500);
This line limits the desired rates sent to the rate loop. A before and after plot shows the performance gain when this line of code is disabled. The Initial state of the copter was roll left at 450° per second. The plot shows the roll angle going to -85°, then recover to 0. Removing that line improve the recovery time from 1.15s to .75s
Suspect code 2:
static int16_t get_angle_boost(int16_t value)
float temp = cos_pitch_x * cos_roll_x;
temp = 1.0 - constrain(temp, .5, 1.0);
int16_t output = temp * value;
return constrain(output, 0, 200);
static int16_t get_angle_boost()
temp = constrain(temp, .5, 1.0);
return ((float)g.throttle_cruise / temp) - g.throttle_cruise;
This has the effect of maintaining perfect downward acceleration at all times. The reason this works is the throttle-cruise (say 500 out of 1000) is = to 9.81m/s/s of downward acceleration. We can use a linear mapping of throttle to acceleration to achieve the additional throttle necessary for the combined roll and pitch tilt.
Bonus
The last example not is not a patch but a tuning example:
For a basic setup we've been using Rate_P of .14 and Rate_D of 0. Also a Rate dampener similar to the Wii project of .15 Many folks were OK with these gains, but the performance was meh in Max and Marco's experience.
Here is a copter at 45° returning to 0° with the current gains and no patches:
With Patches:
Notice the overshoot and the bell ringing. The frequency with the above with patches is lower and that's good.
Here is the comparison of the above, but with the optimum gains:
These gains are now the default gains:
rate_P of .18
rate_D of .004
stab_D of 0
Please try these gains in the simulator and raise and lower the rate_D term. I was pretty surprised to see how tied the Rate_P and Rate_D are to each other. They cannot be tuned independently. A rate_P of .18 and Rate_D of 0 will not fly well at all. It will fast wobble in the air quite a bit.
I hope this was interesting. The SIM is currently residing at www.jasonshort.com
Jason
Thanks Jason for your great work!
This is great work and will take out some more "real" testing time and damages to our copters!
are you combining this to the other simulator tool used to find bugs? (forgot the name)
I am playing with it and I really enjoy the scripted loops! hahaha I want my switch CH7 to do that!
Superb work Jason (as usual) thanks a lot. Cant wait to see these fixes in action in Firmware 2.6
Dany
Comment by Andreas on June 6, 2012 at 12:18pm Great stuff!
Question to the experts out there:
I remember seeing some amazing control system demos 20 years ago and the term "fuzzy logic" was all the hype. Can fuzzy logic be used to improve PID controllers or is that a complete different approach? Could the APM/AC benefit from some fuzzy logic?
Jason, the current GIT is flying great! Thanks.
Does this mean that you'll be closer to the "one knob tunes all parameters" functionality that is key to an "easy" setup?
I tell ya'... leaps and bounds, man. Nice work.
Fuzzy logic is a different control method which translates "human intuition" into approximate feedback gains.
It’s more suited when you lack a (accurate) mathematical model of the plant, but you know how to manual control it.
As for controlling a quad, a classic cascaded PID feedback control architecture is more suited
What is amazing about your innvation Jason, isn't so much the bugs that you discovered, but how you introduced a rigorous methodology for A/B testing with the ability to do test iterations in minutes rather than hours. Your new methodology basically uncovered stuff it would have taken *thousands* of hours of flights, anecdotal stories and tlogs to figure out.
To Other Andreas:
Now that we can simulate A/B testing, you have the basis for a neural network training scheme (ie. a fitness test). It would be interesting to consider "evolving" control schemes or tuning parameters or both using a neural net.
Comment by Marooned on June 6, 2012 at 11:15pm This is just begging for neural network to find the best values for PID variables.
Comment by Greg on June 7, 2012 at 3:41am Nice work Jason.
Comment by Tim - Arduino for Visual Studio on June 7, 2012 at 8:38am Great stuff
1277 members
183 members
246 members
179 members
Powered by
