I thought I would share a couple of photos of the quick connector I soldered on to my arducopter Sonar which incorporates the power filter I posted a while ago (Link). I started experimenting with different sonars from MaxBotix and wanted a way to incorporate the passive filter and connector together. Over time having everything wired up including the resistor in the +5v line seemed to eventually break with the cable moving / being unplugged from the APM. If you look closely you can see I have the 10 ohm resistor going into the +5v on the Sonar board and the other end connects to the appropriate edge connector pin. I find this setup very reliable when swapping out parts for testing.
Here are some other photos:
The above photo shows the 100uF Electrolytic mounted across the +5v and gnd.
very nice and clean! wish these sonars came like that from factory!
good work!
Greg,
I have also used the power filter approach above, but not the connector. Instead mine has a long rat-tail cable hanging off the sonar.
Despite the long cable, I dont seem to be getting interference and I'm getting superb sonar results.
thanks for the power filter tips!
I also use the rat-tail method, and I hotglue the resistor, cap, and the beginning of the rat-tail to the board, for strain relief.
Comment by Greg on June 7, 2012 at 1:22pm
Comment by Jack Crossfire on June 7, 2012 at 6:57pm Haven't seen one of those giant trimpots in decades. That thing must allow it to communicate with Michael Jackson in the afterlife.
@Jack Crossfire,
The "giant trimpot" looks more like a tunable inductor for the sonar's oscillator's tank circuit maybe?
TCIII
Great tip... and thanks for the hi-res pic that makes it easy to see what you're talking about!
Comment by Rick Stewart on June 15, 2012 at 2:44pm What purpose does the resistor serve?
Rick
Comment by Greg on June 15, 2012 at 4:16pm
Comment by Rick Stewart on June 15, 2012 at 5:03pm Wow, thanks Greg, I have been playing around with simple electronics during my hexa build. This will be the perfect addition to my knowlage base. Thanks,
Rick
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
48 members
693 members
51 members
249 members
Powered by
