As most of you may or may not know, I've been a big proponent of using PPM Sum (aka CPPM) with the Ardupilot since I first figured out how to make it work. The simplicity of just running a single wire from the Rx to the APM is very attractive. It eliminates 7 possible failure modes (losing the wire connecting channels 2-8) which could result in loss of control. There's only 1 wire to get right, but also one wire to get wrong. Fortunately, the APM can handle complete loss of signal well, and if you set your failsafe to handle complete signal loss, all is good.
I was using this on my HK450GT FBL helicopter, along with a FrSky D8R-SP Rx. Again, as anybody who knows me is aware, I'm a big fan of FrSky radio equipment. It is affordable, and high performance offering true diversity on the Rx, easy to use CPPM (just requires a jumper on two pins), the Rx is very tolerant of low voltage (it'll keep going LONG after the APM would have shut down, down below 3V). And rebooting and reacquiring the Tx signal takes less than 1 second.
All of these features are superior to the big name brands, Futaba, Spektrum, etc.
And the telemetry features offered by FrSky is just the icing on the cake. RSSI (signal strength), Rx voltage, external voltage (flight battery), and even the option for a telemetry hub with all kinds of goodies This is somewhat negated by using an APM, but still, you can put one of these on your Tx and have all the info right at your fingertips.
Anyway, back to my little 450 heli with a HUGE Rx mounted on it, the D8R-SP.
I discovered that FrSky offer a new Rx, the D4Fr which is a small, yet full-range Rx. And while it only has 4 channels out, it can be configured to do 8-channel CPPM with the simple addition of a jumper! Brilliant, and there's no reason why any modern compact receiver shouldn't be able to do this. This Rx does not have as many telemetry features as it's big brother. It can only report RSSI and Rx Voltage, it does not have connectors for the telemetry hub or external voltage. But that's fine, as the APM can be used to report voltage anyway. So I ordered one and it arrived Friday.
I started working on setting it up, when the wheels started turning in my brain. The "case" is just a flimsy plastic thing, almost useless anyway. And I'm only going to have a single cable going from the Rx to the APM, and it's so small. And the APM2 has those stand-off pins onto which the daughterboard is soldered. And those pins are kinda long... And I've got this piece of empty prototype board sitting around...
Pretty soon I had de-cased the Rx and stripped all the input pins off the APM2.
I soldered the proto-board to the daughter board standoffs, and then glued the Rx board onto the proto-board. I soldered jumpers on both the Rx and APM2 in order to set both into CPPM mode. And then I soldered a jumper wire for the CPPM signal, power and ground. Done.
The complete unit is compact. There's no wires to get in the way of whatever vibration-damping mount you are using. There are no wires to come disconnected. I suspect this setup is at least an order of magnitude more reliable than a standard 8-channel APM2 setup.
Even better, it's compact, and easy to move between vehicles.
Comment by Tim - Arduino for Visual Studio on June 10, 2012 at 4:24am very nice. well done!
@All: I did a quick test with this and it seems to work. The only issue is that it seem that having the telemetry transmitter so close to the GPS puck causes a bit of trouble. It takes about 5-10 minutes to get a lock, but then after that it's fine. It doesn't seem to affect the performance. If that is a problem for you and you don't want telemetry, maybe you could use this Rx?
http://www.hobbyking.com/hobbyking/store/__22692__FrSky_TFR4B_2_4Gh...
This isn't a problem for me as I use a seperate battery for the APM2 typically, so I just plug it in first and by the time I've set everything up, it's good to go.
I would LOVE to set up the APM to output telemetry to the D4FR-ii Rx. That would be GREAT. It's a bit beyond me but maybe we can work on it together. Ideally I'd like to use the same protocol as the sensor hub, so that the remote display works the same way. This appears to be the protocol that the Sensor Hub uses.
http://www.frsky-rc.com/uploadfile/201107/20110727110301692.pdf
I love that FrSky provides this info!
@Chris Huitema, yeah, I have a few older FrSky 8Ch Rx, and I had to flash them for CPPM as well. It was a little more involved because the older one required an extra electronic widget and had to be decased. But I got it done.
@Veikko, you're on your own for that one. ;) I have no SBus equipement, and not a lot of interest in delving into it. It's expensive and closed source.
@Daniel, yes, the APM1 can also take CPPM input if you have the updated firmware. If you bought recently, it should have it already. It the unit is old, it does not, and you'll need to update the PPM firmware. You'll have to figure out the details for mounting, as it's not as obvious, but should be possible.
Comment by Ravi on June 10, 2012 at 6:37am can someone suggest which jumper on APM 2 has to be shorted to supply PPM to IN1.
Ravi, it's the signal pins for 2 & 3 that need to be shorted together. Just like APM1. The wiki is wrong about APM2.
Comment by Veikko Vierola on June 10, 2012 at 10:05am So is there any possibility to connect futaba receiver directly to the board the same way it's done with the FrSky Rx instead of trying to implement S-Bus?
Comment by CharlieNoFun on June 10, 2012 at 10:12am @Veikko I read S-Bus is an inverted logic TTL serial connection, I think it would take a good bit of effort to support that vs PPM. Not sure if the hardware pin used for PPM sum is going to work without an hex inverter chip (thats how Mikrocopter does it if i'm not mistaken).
Comment by Veikko Vierola on June 10, 2012 at 10:27am
Comment by Patrick L on June 10, 2012 at 10:42am FrSky also makes the Futaba FASST compatible TFR4B. This 4 channel full range rx is quite cheap, small and light and can output CPPM and RSI using the jumper method. It works like a charm with APM2 and my T8FG.
@Veikko: I don't know about the TFR6, but there is no mention of CPPM in the manual, so probably not.
Comment by Veikko Vierola on June 10, 2012 at 11:02am @Patrick L
Yes the TFR4B could work, but then I need to leave the flaps out of my plane or perhaps make the aileron connection with Y-cable to save the channels. Basically I need 5ch rx at least. If someone knows a Futaba compatible FrSky rx with more channels than 4 and with CPPM/RSI, please let me know.
I just came back from the flying field using the all-in-one. I put it in an old 80" Piper Cub with a Saito 4-stroke that I haven't flown in 8 years. It worked pretty well. The range was quite a bit shorter than I'd have liked, as it was warning me about the signal at about the distance that I would fly a regular RC airplane at.
It might have been because I was using a transmitter tray, and the result was the Tx antenna was basically pointing at the aircraft, which IIRC is bad?
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
206 members
52 members
719 members
203 members
Powered by
