Finally my x550 and APM2 quadcopter is complete! And I have successfully flown!.
Right now I seem to have a bit of  yaw problem, as well as a trim/balance issue. Since the frame is not quite flat it can be hard to tell exactly what should be level, and when I yaw in a different direction, it seems to always return to original. I think I need to check my motor position perpendicularity and possibly PIDs.
Tags: Arducopter, X550, first, flight, maiden, quadcopter, quadrotor
Comment by ikrase on June 10, 2012 at 11:09pm
Yeah. Do you think I need more I in the yaw PID?
Comment by Christiaan van Vollenstee on June 11, 2012 at 11:29am
I had one of those x550's as you can see in my profile photo, it is very hard to set those PID's. First you need to replace those motor mounts with alumenium mounts becasue those carbon fiber will throw your PID's out very unstable. Second do not use motors over 1000kv with that frame, the best is about 850 or 880kv.
Hope it helps.
Regards
Christiaan
Comment by Christiaan van Vollenstee on June 11, 2012 at 11:35am
O ye here is videos before I started stabelizing the frame
http://www.youtube.com/watch?v=dWYBy8n3lbs
and here is where he is much stabler but also not stable enough.
http://www.youtube.com/watch?v=TIBPWh6gK5Q&feature=relmfu
Comment
