Comment by Crispin on June 17, 2012 at 3:27pm That's, err, quite interesting :D
I wonder how many half-props I have thrown away :(
Comment by patrice.rance on June 17, 2012 at 3:35pm Thanks !!! sometimes simple ideas can be money saving ;)
Comment by Rana on June 17, 2012 at 5:13pm Never ever do that. If you can bear the loss of your quad then its okay. This I am saying out out of my long experience on quad.
Comment by Rana on June 17, 2012 at 5:15pm Furthermore it will give additional vibration as you won,t be able to perfectly balance the hub of the prop.
Comment by Jack Crossfire on June 17, 2012 at 6:17pm Makes you miss the days of the local hobby shop.
Comment by Ellison Chan on June 17, 2012 at 6:22pm Maybe a desperate solution, when you're absolutely out of props, and can't wait weeks for a new set. But, I have a question, do you glue the two props together? If not, how do you prevent the two blades from slipping relative to each other?
Comment by patrice.rance on June 17, 2012 at 8:23pm no i test it on my HEX6 and everything is cool with no glue !!!! even with my hand i cannot change the position !!!
just test it and tell me what you think !!!
may be on a quad you can have vibration but you fly anyway ;) trust me.
Comment by Maxime Carrier on June 17, 2012 at 9:19pm Tested with ABS Glue, no success (exploded after running 30 seconds)
Maybe with crazy glue .... so you need to hold piece together with lot of pressure.
Comment by Ellison Chan on June 17, 2012 at 9:27pm Yeah, those motors that Patrice is using has the thread integrated into the shaft, so a nut on the bottom and nut on top, and you can generate large pressure. Still, I would wait for new props, and put the broken props in the blue box for proper recycling. ;-)
This has to be an April fool, don't fly anywhere near anybody else with that setup. There are two sorts of people in this hobby, those that have been hit by a prop and those that are about to be.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
